Alignment question
Old May 17, 2010 | 01:34 PM
bighank's Avatar
bighank
Default Look at changing BOTH tie rods
Originally Posted by aschiftner
Well, the tires should be in tomorrow. The outer tie rod will not be until Tuesday. I think I'll be getting the tires on first. Thanks guys. R/ Al
I've replaced tie rods before just not on my C5. Then had the car aligned IMMEDIATELY. If one outer rod is worn or sloppy chances the other side is also ready for replacement since they should wear at about the same rate. Better to have both new tie rods rather than change one in six months and have to realign the car again.
Old May 17, 2010 | 02:23 PM
BUGZ's Avatar
BUGZ
Originally Posted by 87SAM
I'm in the do it with the new tires group.
