'01 Z06 Clutch Problems
Old May 14, 2010 | 09:21 PM
Drunkmagnet's Avatar
Drunkmagnet
Default '01 Z06 Clutch Problems
Hello,
I have a 2001 Z06 with a fully built 412. Well it has the Spec twin disk clutch set in it. Clutch should have about 2K-3K miles. Car was making roughly 980whp untill recently I have switched to a all motor setup making right at 550whp. Recently the clutch has been slipping once the car warmes up or driven maybe 5-15 miles.
It will slip leaving a stop light gently or roll on the throttle in 5th or 6th it will slip. How ever if you stomp on the gas in 1st-3rd it will burn the 345's and go like crazy. Does not seem to make sense to me. Slips under low load but hooks under high load.
I dont want to drop a few thousand on a clutch for that not to be the problem.
Thanks,
Tim
Old May 15, 2010 | 07:45 AM
SargeZ06's Avatar
SargeZ06
Sounds like there is oil/grease on the clutch disk. Pull the bottom flywheel cover and take a look. May or may not be able to see.
Sometimes people damage the oil seal in the back of the crank where the pilot bearing goes when the are taking the old one out. OR they will pack the new bearing with grease (a big NO NO) when they install it because it looks dry. Everything gets hot and grease gets slung on the disk face.
Old May 15, 2010 | 01:46 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Jack up the car and pull down the inspection coverand see what's going on.
Originally Posted by Drunkmagnet
Hello,
Thanks,
Tim
Old May 15, 2010 | 08:28 PM
USAFZ06's Avatar
USAFZ06
slave shim installed or not?
Old Jun 17, 2010 | 10:03 PM
Drunkmagnet
Ok, about got the cash together to get the clutch done... can anyone recomend a good clutch to go with...?
Old Jun 17, 2010 | 10:11 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Did you check any of the things everyone said to check? If you can floor it and it not slip, then there is something on the disk.
To '01 Z06 Clutch Problems
