Lowered c5 but no difference.
Old May 15, 2010 | 09:57 PM
Solofast's Avatar
Solofast
Originally Posted by jpizzlemtg
Solo, just a question then to address what you are saying.
One how can a garage not be level unless the person who built it was an idiot? A garage has to be level to comply with building codes.
Second I can raise it up to 3 notches in the rear but so far I have seen no difference in handling at 1 notch.
Don't know where you live, but where I live a garage floor, BY CODE has to be sloped to drain water. I have a 4 car garage that has a drain in the floor in one bay, and it is sloped in two directions to make sure water gets to the drrain. In the other half of the garage, when I had my house built the builder poured one side of the garage flat and leveled with a laser so I could set up suspensions for racing. We put a bunch of stuff in the garage so that the inspector doing the final inspection wouldn't notice that it wasn't to code.
Now to the second question, first of all it may or may not have setteled all the way, but you won't notice the bottoming right away if you aren't driving on rough pavement or aren't cornering at speed and hit a bump. The stock bump stops are pretty progessive, and you will just think it's a bit more firm as opposed to slaming down on every bump. What's nasty is when you hit a bump when cornering hard and cause the car to oversteer.
Old May 15, 2010 | 09:58 PM
socalman's Avatar
socalman
St. Jude Donor '10
Sry socal no its been a long day those are suppose to be 28 rear and 27 front numbers. but as you can see if they are stock at 27.5 I am seeing litterally no change in fronts. I have 5-6 notches showing on front bolts. ok so here is my question how do i measure rake on these cars because its soo hard to measure with measuring tape on ground to jacking points and get exact. I can easily do it with fenders thx.
Well, again, using the fenders, the stock rake would be:
rear is 1.5" higher than the front
rear is aprox 29", front is 27.5.
If you're at 27 at the front, that is the max you are going to get out of the stock front bolts (27-1/2" stock to 27 lowered), until you remove them and cut off the bushing. The bushing is around 3/4" high. You can get the 'Zip' front bolts which are like someone posted, C6 which have a shorter bushing.
At 28 in the rear, you are good without getting into the shock bumpstop (you actually might be at that height), but that's another story.
Check your PMs for some more info
Old May 15, 2010 | 10:03 PM
Z06supercharged's Avatar
Z06supercharged
Actually the C6 bolts dont have a bushing at all. Its just a solid flat thicker bottom plate with some rubber coating on it.
Measuring at the frame right next to each puck hole I just use a large tape measurer on its end which is like 3" or so and pull the tape up from it to the frame.
Hard to really get a typical measurement from everyone what is normal lowered height as there are different rims and tire heights being used.
Old May 15, 2010 | 10:07 PM
Solofast's Avatar
Solofast
Good stuff here Solo, as always! I've been working hard to find a shock that is lower in the C5 tech area, but as you stated, you'll be riding on the bumpstops and it hurts! What do you think about coilovers vs. the spindles?
I am not a huge fan of coilovers, a lot of expense for not a big improvement. If you are racing and want to make spring rate changes quickly there is a real advantage, but for street and anything short of pro racing there is really no need.
Even with coilovers, if you lower the car too much the geometry will be messed up and there will be issues with bump steer and lateral roll center movement, so if you want handling AND a low ride height dropped spindles are an advantage, but they are expensive.
Slightly lowered ride height with stock geometry, the right springs (like Z06 or stiffer) and a good set of performance shocks with an aggressive alignment will make these cars into amazing handling machines. Add sticky tires and you can just about extrude your brains out of your ears with the g forces they can make... To give you an example, a good stock Z06 with shocks, a performance alignment and a set of Hoosier DOT sticky tires will hit 1.25 g's all day long...
Old May 15, 2010 | 10:13 PM
socalman's Avatar
socalman
St. Jude Donor '10
Do you think going from a base suspension on my coupe, to a Z06 rear spring, will help the shocks from bottoming out so easy if I drop the rear 1.5"? I really like the look at that drop, but I'm sitting using 1.5" of the travel left on the shock (after removing the bumpstop). I have Bilstein Sports and C6Z51 sways, metal endlinks. Also, would it increase or decrease any handling or bottoming out if lowered and I used adjustable endlinks?
Old May 15, 2010 | 10:15 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Originally Posted by bobby777
My wifes rear-end has lowered by 6 inches- But the ride is smooth-
Did you measure her from her jacking points?
Old May 15, 2010 | 10:16 PM
socalman's Avatar
socalman
St. Jude Donor '10
Thanks, I couldn't tell it was not rubber. So, seems the C5 bolt can give you a little more by cutting of the rubber all together.
I measured quite a few cars, along with searches here, many report about the same at the fenders. I know fenders can be off, but if we're just going for a look, and you measure from the fenders on a level surface with tires at same pressure-and the fenders measure equal both sides, it's an easy place to start when lowering. I know I measured mine before I started and they were the same both sides within less than 1/16th.
Old May 15, 2010 | 10:48 PM
jpizzlemtg's Avatar
jpizzlemtg
OK Update!
I got the driver side bolt to move I just had to remove bottom of shock to get a wobble in there. Anyways front passanger and driver and fully out I left bushings because its not that big a deal to me. And on the Rear I put them at 3 grooves left I had it at 1 groove and I heard the bumpstop thumping at a stop taking off a couple times haha.
Anyways I am coming from a import racing background and so as you said you do not like coilovers I still believe that are the only option for a super aggressive lowered look and still good performance.
Old May 15, 2010 | 10:49 PM
jpizzlemtg's Avatar
jpizzlemtg
Now I drove about 10 miles with 3 grooves in the rear, but my other question was will 3 grooves still hit bumpstop it does not seem like it does from testing so far but I have not hit huge bumps.
Old May 15, 2010 | 10:58 PM
socalman's Avatar
socalman
St. Jude Donor '10
The stock shock (or Bilstien) has about 1.5" of travel after the cars weight. If you lower 1/2", you now have 1" travel and so on. 1" will leave you not much in the way of travel, so you will feel it on a hard bump.
Old May 15, 2010 | 11:39 PM
Z06supercharged
I had my stock rear bolts all the way to the little safety washer thingy so no threads showing at all. My stock shocks still did not bottom out. You just have to experiment around to see where it is.
BTW a sloping garage floor is not going to slope that much over the distance of both wheel center lines. I just went out and checked my garage floor and the whole 25 feet from one end to the other slopes 1/4" according to the laser level and the 9' from wheel to wheel slopes less than 1/8".
Also I tried Bilstein sport shocks and didnt like them at all and took em back off. A great shock for the street are Pfadt adjustable inverted sport shocks for around $800.
Old May 15, 2010 | 11:57 PM
jpizzlemtg's Avatar
jpizzlemtg
I have not noticed bottoming out. but I will keep driving it this whole week and then make adjustments if i feel like it. To be honest though in my opinion just lowering it the 1 inch in rear and .5-1inch in front is all the car needs until you have money to purchase an adjustable coilover set. If you truely want a lowered corvette with an aggressive look you need coilovers.
Old May 16, 2010 | 09:09 AM
  #33
Solofast's Avatar
Solofast
The slope isn't what is important, it is the twist. If the floor is flat from side to side a bit of slope makes no difference. But, if say the right rear wheel is lower than the left front by 1/8 of an inch, this will jack about 25 pounds from corner to corner if you set the ride height equal with the wheels offset that much. A jacking of about 25 pounds is where you start to feel the difference, at 50 pounds of jacked cornerweight a good track driver will tell you that you setup is all screwed up and the car will have a noticable difference in handling turning right and left. This is why it is important to get a level surface to do your setup on.
Old May 16, 2010 | 12:11 PM
  #34
jpizzlemtg's Avatar
jpizzlemtg
just so people get an idea i am at 27.75 rear with 3 notches and 26.75 aprox front all the way out. this is still with bushings.
Old Aug 6, 2014 | 09:34 PM
  #35
1998BlackPlasticToy's Avatar
1998BlackPlasticToy
I lowered mine on a set of lowering bolts purchased on Summit for $65. Made it simple. Did it 1" all the way around. Looks GREAT. Handles excellent. Ride is changed but not uncomfortable.
Definitely have it aligned after. My alignment was WAY out.
