Lowered c5 but no difference.
Another question I had is on the rear I have it set at 1-1.5 thread left on each side and on the front I was able to get about 7 threads out of driver side and way more out of passenger if I wanted to keep going I was at about 8-9 why is this? I put both at 7 but I was curious as the why the drivers side is tight at 7 and the passengers had a lot more to go.
Thx for the info guys its different lowering these cars compared to S2K's
One good way to do it is to lower the bolts at each end of the car the same amount, that is a lot closer way than just getting under there and jacking with the screws. If you have dorked with it and moved the screws unequally, then you need to find a level surface and set the ride heights properly.
2. The thread counts won't be even from side to side or front to back, they will be all over the place. Since you have made it the same you are jacking weight from corner to corner and you can expect funny handling.
3. 1 to 1.5 threads in the back is too low. Unless you have shorter shocks you WILL be bottoming out the back shocks at that height (been there done that). The car will ride rougher than a cob, and if you are cornering and hit a bump you will get severe oversteer. You want to see at least 3 threads on the lowest of the rear screws to be in the right range.
4. The suspension geometry of these cars is designed to work in a correct range. Lowering more than that just screws up the handling. It continues to amaze me that people keep lowering these cars more than what is correct thinking that "lower is better" and "more lower is more better". It is simply stupid. If you want to lower the car more that what I've described, go get a set of lowered spindles (for big bucks from LGM) and have at it. But if you are using stock geometry you are simply screwing up a good thing if you lower it too much.
One how can a garage not be level unless the person who built it was an idiot?
A garage has to be level to comply with building codes.
Second I can raise it up to 3 notches in the rear but so far I have seen no difference in handling at 1 notch.
Once the shocks bounce a couple times thats it and its done.
I measured/tested my stock Z06 shocks after it was lowered max in front and with lowering bolts in back down an inch and they still had .75" compression left on them front and rear.
Ive seen some stock shocks bottom out though when car lowered and it would never "settle" right.
Once the jack is lowered down and suspension jounced a few times there is literally nothing that would need time to settle more unless something was binding and in that case needs to be looked at.
I measured my height fter lowering at frame f/r after a drive around the block and again at 40 miles and there was no difference at all. If someones is not settling for 100+ miles then then something else isnt right.
First off there is no way they adjust in the front after 1 ride, the rears do but the fronts will not. For instance I started off today with 17.25" on driver side and 16.9" on passanger. I knew that I could not lower the driver side anymore because it was too tight already so I decided just to raise the passanger to 17.25 also I tryed to do this and have ended up at 17.2" passanger currently but my driver side without any change is sitting at 17.7" why is this? it makes no sense to me anyways I will go get gas brb
17.25 front pas, 17.5 driver. The problem that is coming up is that I do not know if I can adjust the driver side because it will not loosen any more.
The way I do it is measure under frame F/R to get 1/4-1/2" rake. You can start at wheel well lips to get it started but its the rake of frame for correct measuring points and distances. You are gonna go postal changing a little on different sides trying to get em all evened up. You make 1 bolt change on 1 side and its gonna change other side aswell without even touching other side.
I also used C6 front bolts on my C5 as they dont have rubber bushings on them so its like cutting 1 bushing off the C5 bolt so its lower than stock c5 bolts. Here is difference between the C6/C5 bolts.
When I lower mine and re adjust, one quick run through the neighborhood, a 2 mile loop on the freeway, and I'm settled to the max.
If you started at stock, measured to your fenders and they were all the same (rear same both sides, front same both sides) then we would know 2 things-
the car started level using fenders (they're just easier to measure than frame bottom)
How much you are dropping.
Stock bolts will let you go like this
Front: 1/2" max drop on the stock bolts...BUT- many times the bushing is smashed and more so on one side, causing one side to start out higher than the other, and even after you adjust, one side will go lower than the other (if the bushing is smashed).
Best thing is to remove the front bolt, cut them off so they are even (I cut mine to 1/8"- just enough for cushion so I could max the car without removing.
Max with 1/8" you'll get 1.5" drop- removing the bolt gives you another 1/2".
Rears; you can get 3/4" if you max out the stock bolt (leaving 1 thread). Each thread is about 1/8" in change of height (I know, I've changed mine 10 times the past 3 weeks). You can get more if you cut off a rib on the bushings that hold the bolts. Each rib is 1/4"- so I cut 1 rib from each (top/bottom) and you can get a total of 1-1/4" drop.
Want to see more- look at this
http://forums.corvetteforum.com/c5-t...ng-the-c5.html
But the ride is smooth-
