Power seat frame bracket broken
Old May 16, 2010 | 11:01 PM
rosecarl's Avatar
rosecarl
Default Power seat frame bracket broken
Hi everyone,
First, thanks for all your help. In time I will learn a bit more about this car. I just recently purchased a 2002 6-speed car; in the process of replacing the driver's side carpet I removed the seat (driver's side power seat with memory function), only to find one of the main frame brackets was broken (see image):
(hmmm....having difficulty uploading image from my camera)
In searching the archives this has arisen before, and parts are not available individually. When replacing this track, do I need to search specifically for a LH track with power & memory or will a standard power track work? (and can I simply swap over the motors, etc.)
Thanks again for your time,
Carl
Old May 17, 2010 | 02:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Cant you just weld it? I would try that first.
You have to host you pictures on something like PHOTOBUCKET and then copy the IMAGE file and paste it into your post. Photobucket is free and easy to use.
BC
