oil pan torque
Old May 17, 2010 | 01:29 PM
jimish's Avatar
jimish
Default oil pan torque
It says right on the pan special torque and sequence for tightening. I don't have a service manual so can anyone answer the tightening procedure. Also, the gasket looks pretty good, they can be used over, right.
Old May 17, 2010 | 01:34 PM
jimish's Avatar
jimish
By the way its an '03
Old May 17, 2010 | 01:36 PM
lucky131969's Avatar
lucky131969
I can email you the service manual procedure. With regards to the gasket, considering what is involved in replacing the oil pan/gasket, I would install a new one.
Old May 17, 2010 | 02:49 PM
jimish's Avatar
jimish
Thanks Lucky13... You can e-mail me at J1M1SH@aol.com
Your right on the gasket, the pan is off and clean so I might as well put a new one on (as long as its not ridicously expensive. Thanks again.
Old May 17, 2010 | 02:51 PM
lucky131969
Procedure sent
Old May 18, 2010 | 08:12 AM
jimish's Avatar
jimish
Got it, thank you. I ordered the gasket. It says tighten in a criss cross pattern, I thought it had a specific sequence like the intake manifold or a head.
To oil pan torque
