Radiator petcock replacement
Old May 18, 2010 | 04:28 PM
puzzleboy's Avatar
puzzleboy
Default Radiator petcock replacement
Changing my balancer, etc. Went to drain the coolant, and PO or backyard Bob must have messed up the petcock.
Ordered a new one from GM. How does the old one come out? What I see right now, is a plastic cone about 1/4 inch long, and underneath that is a rubber gasket/grommet of some sort. Inside the cone I was expecting to see a square and allen head recess, but it looks all messed up.
I yanked the lower rad hose to drain the coolant.
Does the rad have to come out to change the petcock?
Thanks!
J
Old May 18, 2010 | 04:38 PM
lucky131969's Avatar
lucky131969
Thanks!
J
What is "messed up" about the petcock?
Old May 18, 2010 | 04:45 PM
puzzleboy's Avatar
puzzleboy
There's no recess in it to turn it the 1/4 turn. It's either been stripped out, or replaced with some kind of aftermarket one. Not sure.....
Old May 18, 2010 | 06:24 PM
lucky131969
There are a couple of different types. One as you stated, has accepts a 1/4" drive, and the other just has wings on it so it can be turned. Sounds like the wings have been broken off. Post a pic if you can.
Old May 18, 2010 | 08:10 PM
Nick1's Avatar
Nick1
You need to look up and behind the cone where the fluid comes out of. Then you will see the infamous white plug/valve which looks like nothing that you ever seen. It faces the lower area of the engine.
As noted above, a 1/4" driver will open it with a quarter turn counter-clockwise. Do this cold or else.
If you wiggle it a bit after the quarter turn, you can pull it out while twisting it lightly a bit more. Of course you need to have a drain pan ready to catch it all. It can be a bit messy but a real problem when it's hot. There is a replacment valve with "wings" on it which you may be able to order from Autozone, to make future drains much easier. Good luck!
Old May 19, 2010 | 12:35 AM
paulrc5's Avatar
paulrc5
I just bought a replacement yesterday at Napa for about $7. Their PN is:
BK 6051371
Old Jul 14, 2025 | 07:43 PM
RiverBoy's Avatar
RiverBoy
Hello. Mine is also broken, and I had to practically pull it apart with a pair of pliers. Does it pop all the way out with enough force and then it's just a matter of putting the new part back in its place?
Old Jul 14, 2025 | 07:49 PM
lucky131969
Force not required ! Just turn 90 degrees CCW and pull out. There is small metal pin that acts as a retainer.
Old Jul 14, 2025 | 07:55 PM
RiverBoy's Avatar
RiverBoy
Thanks king. Will update when part arrives.
To Radiator petcock replacement
