new cam, Dyno graph. Experts please help
Old May 18, 2010 | 05:46 PM
trk982003's Avatar
trk982003
Default new cam, Dyno graph. Experts please help
Installed my new cam here's the dismal results... additional info can be found at this thread http://forums.corvetteforum.com/c5-t...nd-dyno-s.html.
Old May 18, 2010 | 05:51 PM
happa's Avatar
happa
Something isnt right. I had a stock 99 coupe MN6 with Borla Exhaust and I made 345 rwhp. The air/fuel looks ok. Not sure if something else is failing. Very odd, hopefully some one will chime in and help.
Bryan
Old May 18, 2010 | 06:06 PM
trk982003's Avatar
trk982003
Thank you me too, im pullin my hair out over it. Its not the dyno because he showed me stock corvettes with better numbers. I have borla stingers and open air box with a k&n.
Old May 18, 2010 | 06:17 PM
lucky131969's Avatar
lucky131969
Unless I'm missing something, you have an unresolved issue with the knock sensor(s). As long as the knock sensor is sensing a false knock, the PCM will pull timing. I had this happen to me as well. If the intake has been off, you may have pinched the harness, or may have a bad sensor. You can have the tuner turn down the sensitivity to see if that helps as well.
Old May 18, 2010 | 06:26 PM
trk982003's Avatar
trk982003
The knock sensors are working properly as far as I know. The tuner was only able to get 21* of timing without KS intervention. He was using HP tuner and was showing me anytime the KS was active, on this graph it did not activate. Thanks for your idea! He thinks its suspicious that he can only get 21* he said he would like to see around 27*. He suggested plugged cats? Any ideas?
Old May 18, 2010 | 06:45 PM
lucky131969
According to your other thread, this is the most timing he could run without the knock sensor pulling timing. So the question still remains: did he actually observe/hear knock with more timing, or is the knock sensor(s) sensing a false knock? This needs to be resolved before trying to move forward.
Old May 18, 2010 | 07:15 PM
trk982003's Avatar
trk982003
I see what your saying, hmmm. To answer your question the intake has not been off. We were thinking that too much back pressure is whats causing the KS to react. Its has 4 cats, and they're aftermarket rebuilds. (still $1200 pipe at the time) and maybe leaning out the mixture? The dyno graph plateaus hard around 5k rpm. I'll certainly suggst the KS sensitivity to him, but i wanna safe tune. Detonation makes me cringe and never wanna hear it. Thanks for your input it makes sence to me.
To new cam, Dyno graph. Experts please help
