Pull key wait 10 seconds
Old May 18, 2010 | 07:25 PM
Pops Racer's Avatar
Pops Racer
Default Pull key wait 10 seconds
What do I have to do to stop getting this message??? CLB was done early this year everything else seems to be fine. Details 2000, automatic, sits hooked to a C-Tek 3300.
Thx, Jim
Old May 19, 2010 | 12:21 AM
Carcass's Avatar
Carcass
If you're just getting the "pull key" message,and it's not accompanied by the "service column lock" message,you may just have worn or dirty resistor contacts in the ignition switch.
Try cleaning the pellet on the key,and the contacts in the switch, with a q-tip and some rubbing alcohol.
If that helps,but doesn't totally cure it,you may need to get into the switch and re-tension the springs on the contacts.
Do a search-there's a thread somewhere on how to do it.
