Frame Savers Why did I wait?
Old Mar 18, 2002 | 03:07 PM
dumbkid's Avatar
dumbkid
8th Gear
Default Frame Savers Why did I wait?
I should have done this a long time ago. Both my front bars and my rocker panels were taking quite a beating. Last month I intstalled Andy's combo (A&A Corvette Specialties) including the rocker rails and Frame Savers. What a difference. Where I used to hammer my front end , I feel no more than a solid bump and just let the front end roll instead of scrape. The rocker rails have saved me a couple of times also. I drove off a curb the other day. You know, missed the driveway out of a gas station and slammed the rocker panel into thr curb. Ouch! Checked it later ( was too embarassed to stop ) and just a gouge in the aluminum rail. No damage to the fiberglass!. Kudos to Andy and his inventions. Highly recommended! :cheers:
Old Mar 18, 2002 | 03:18 PM
Dale RED 98's Avatar
Dale RED 98
Default Re: Frame Savers Why did I wait? (dumbkid)
Frame Saver's really help on my steep driveway! I was alway's dragging the nose! No more drag. THANK'S Andy!!! :cheers:
Old Mar 18, 2002 | 03:56 PM
RDVT4ME's Avatar
RDVT4ME
Default Re: Frame Savers Why did I wait? (Dale RED 98)
They saved my butt yesterday when I pulled in to far and ran the nose up on one of those cement slabs (the ones you see in parking lots). Well, it just rolled up on the frame savers. Thank you Andy!!!!!!!!
Man it is tough to know where the front end of this car is.
Old Mar 18, 2002 | 04:40 PM
vettenuts's Avatar
vettenuts
Default Re: Frame Savers Why did I wait? (RDVT4ME)
What is the URL?
Old Mar 18, 2002 | 04:48 PM
ddawson's Avatar
ddawson
Default Re: Frame Savers Why did I wait? (vettenuts)
Agreed. I didn't angle a driveway last week and I just rolled over.
http://www.aandacorvette.com/
Old Mar 18, 2002 | 05:14 PM
Crash99's Avatar
Crash99
Default Re: Frame Savers Why did I wait? (ddawson)
I just ordered a set of Frame Savers and Rocker Rails yesterday. To those of you who installed it, do you have to drill holes in the body/frame for the rails? (I know you have to drill holes for the Frame Savers).
Also, my skid plates are thrashed (thanks to the previous owner), how does one replace those?
Thanks,
Crash
Old Mar 18, 2002 | 05:52 PM
jayleone's Avatar
jayleone
Any help on the front are dam? I rarely have any trouble with the front frame rails, but my driveway is just steep enough to scrap the plastic dam every time. Really annoying.
Old Mar 18, 2002 | 05:53 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
:cheers: :cool:
Old Mar 18, 2002 | 06:40 PM
RDVT4ME's Avatar
RDVT4ME
Default Re: Frame Savers Why did I wait? (2000^C5)
Crash99
You will be drilling 4 -3/16" holes into the frame for each side. The rocker rails fit quite nicely. There are indentions in the rocker rails to fit over a couple of bolts. Alignment is very easy. I recommend a very good drill bit and it will work out nicely.
[Modified by RDVT4ME, 2:41 PM 3/18/2002]
Old Mar 18, 2002 | 06:53 PM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
It's amazing how may first time members have gotten these with such great results.:) Cool deal.:cool:
RG
Old Mar 18, 2002 | 10:55 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Default Re: Frame Savers Why did I wait? (RG in Dallas)
RG : Thanks for the good words.
Crash 99: Those bars support the radiator and AC Condenser among other things. It's quite a job to replace them. And , as I recall, the part is about $175 I have welded some that were completely worn through. Actually most of the cars I have installed Frame savers on needed some repair of the bars. I would think a muffler shop could repair them a lot cheaper than replacing them. I think a muffler shop is best because they usually have a drive on lift or a pit and a welder handy. I would investigate that first.
Old Mar 19, 2002 | 11:58 AM
Rovent's Avatar
Rovent
Default Re: Frame Savers Why did I wait? (Andy@AandACorvette)
When I first saw these I thought they were sort of a silly idea. I've seen them called"training wheels" etc. But you what? Should have been the first mod I did. Certainly the best one. Just everyday driving is a lot less hassle. I'l bet The wheels come into play almost every day. The rails maybe not as often but the damage they prevent is even more expensive. Good stuff. :smash:
Old Mar 19, 2002 | 12:10 PM
KevsKar66's Avatar
KevsKar66
4th Gear
Default Re: Frame Savers Why did I wait? (Rovent)
cool.
Old Mar 19, 2002 | 06:24 PM
Andy@A&ACorvette
A question I get a lot is "Do I have to drill into the Rocker panels?" No. The only drilling is into the frame itself. The rails mount just inboard of the fiberglass rocker panels with 4 stainless screws . They hang just about 1/8" below the rockers ,therefore they hit before the fiberglass. The aluminum rail just slides over the speed bump or whatever. Sure beats that awful sound of grinding fiberglass! Look at the underside of your rocker panels and your front skid bars. If they are not damaged yet- they will be.
Old Mar 19, 2002 | 08:33 PM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
I'll be giving Andy a call too. I've um.... rubbed the rails a few times on parking stones :( I always get out, act like nothing happened and then take a look when I get back.
Tom
Old Mar 19, 2002 | 11:05 PM
JohnS's Avatar
JohnS
Default Re: Frame Savers Why did I wait? (tbyrne)
When I scrape a parking stop, I noticed that the front bumper barely clears the concrete then the skid bars scrape. If I were to lower any, I don't think anything will help as I would get a direct hit on the nose of the bumper. So my question is how much lower than the skid bars do the rollers hang and, if this is considerable, wouldn't a direct hit be worst than barely scraping? Would it be true that if a car is lowered, the rollers probably wouldn't be much of any help since the nose will be the part that hits? I can see benefits on steep inclines and speed bumps but it is the parking stops that I have problems with - I'm getting better but who know if someone else is driving the car.
JohnS
Old Mar 20, 2002 | 11:51 AM
Andy@A&ACorvette
Default Re: Frame Savers Why did I wait? (JohnS)
Although they are really made for inclines etc. They can help with the curbs too. Although not in all situations. The brackets do not protrude below the bars at all. The bottom of the wheel only sticks below the bar by about 7/16 ". You cant hit the wheel or bracket straight on. It always touches on the lower part of the wheel. Obviously if the curb is too high it will hit the nose first. You still have to be careful of that. But on 99.9% of the inclines, going in or out, and most of the parking curbs they will save you. On a lowered car( like mine for instance) you'd be amazed at how steep a driveway I can negotiate without scraping. Not only do they stop the bars from hitting at all. But that 7/16" extra actually can lift the nose just enough to stop the nose itself from scraping in extreme situations. Ask those who have them. They all love 'em! ANDY
To Frame Savers Why did I wait?
Old Mar 22, 2002 | 02:05 PM
dumbkid's Avatar
dumbkid
8th Gear
Great response to this. You have some great ideas. Hope this brings you some biz!
Old Mar 22, 2002 | 02:15 PM
123Gone's Avatar
123Gone
I put the rollers on the front, I like them. I have not put the rails on and I have never had a problem. Maybe I'm just lucky.
Old Mar 22, 2002 | 02:42 PM
BadBoy's Avatar
BadBoy
You guys are a great influence on my soon to be car but a really bad influence
on my checkbook! I just ordered the frame saver/rocker rail package from Andy. I think it's a small price to pay for the amount of protection these
2 items serve.
