My E85 as a Octane Booster Experiment
dumping gas in per ratio, then ethanol stright into the tank will give lopsided mixes for a while. With your aggressive tune having one tank almost all gas (which the fuel pump is pushing to the engine) can lead to detonation occurances.
Have you logged anyfiles with hptuners to see before/after knock retard?
Read "gusher of lies" by Robert Bryce for some insightful information on the use of alternate fuels and getting free of foreign oil.
Sorry I was blue from lack of breath by the time I got to the cheers.
I have two water test kits, the first one I made up for smaller %, and Quick Fuel has one ofr pump E85 where the % of ethanol is higher.
I also test the E85 I add, and sample from the FI port after driving a while. Knowing what % you had, what size tank, and what you added you can also do math calculation and pretty fairly close.
In colder climates the ethanol % will vary to as low as 70% in winter.
The description below is an older write up I made for some friends, you can use less water (25%), just use a number that is easy to keep track of.
My made up own tester works fine.
A 50 ml is easier, but a 25 will work also. I just put in twice the amount of fuel to water, shake it, let it settle 10-15 minutes and read the bottom layer which will be the ethanol/water layer. Subtract the original water and the balance is the ethanol portion.
Sundays Example: bought 10.73 gals of E85. The sample was 10 mls water, 20 mls e85. Shook it , let it settle, then had 25 mls on the bottom layer (gas is lighter then water).
25 minus the original 10 = ~15 mls ethanol. ~15 divided by 20 original fuel amount equals around 75% ethanol which mixed in my ~25 gal fuel tank gave me a 31% ethanol equivalent in the tank.
With the tune up in it the truck is running great, almost like a 6000 # Vette!! LOL
20% less power causes damage
No it just causes less power. The damage would be e85 dissolving natural rubber fuel parts which I doubt many cars out today still have and am 100% sure the corvette doesn't have.
The only other things I can think of is throwing a CEL because of a different reading from the O2 sensor (but your going to need a e85 tune anyway for bigger injectors and your different stoichiometric ratio)
Or E85 dissolving some crap in your fuel tank and clogging your fuel filter. Which is one of the reasons I may start pouring it in to try and fix my stupid fuel gage. In the end, your car will be cleaner, minus $10 for a fuel filter.
*sources - me, mechanical engineer
WHY:
In the end, even though the fuel offers less power, you will get a higher octane rating which will allow for more boost or a higher compression ratio. Higher compression means a more efficient/powerful engine and a less chance of your engine detonating since the fuel is harder to start to burn.
WHY:
In the end, even though it's less powerful, you will get a higher octane rating which will allow for more boost or a higher compression ratio. Higher compression means a more efficient engine and a less chance of your engine detonating since the fuel is harder to start to burn.
Before tuning I have put 25-30 % ethanol by volume in my 2003 Silverado, 2006 Trailblazer, 2000 Alero, and 2002 Z06 all non flex fuel and never had a code. The ecu read O2 in lambda and as long as the STFT/ LTFT can put in fuel they will adjust. Where you will find a limitation without tuning is high rpm because stock you run out injector. One can raise the fuel pressure or go with bigger injectors. There are cars that go to higher %'s and be OK. My 2003 Silverado is now tuned for full e85 usage and it runs great on it.
It is a incorrect to say the engine will not make power, it will make better power on alcohol, the higher the compression, the more power difference. What it wont do is get the same MPG because MPG is based on BTU's per gal. which gasoline has more the alcohol, and diesel has more then gasoline. Power? That same pump e85 has made as much as 1450 hp in a dual turbo application, cant do that with pump gas!
BTW @ 22-25% the MPG drop is not great, so one needs to do a little math and see where the breakeven point is for MPG, for HP? No contest!
Lastly you are 100% correct on E85 cleaning the system!
The higher compression or more boost will of course make more power from the engine, but you will still be burning more gas in the end to make up for the less power per gallon.
I mean $2.97 * 20% more fuel used vs 8 dollar race gas, theres no competition
Gains would be minimal on a NA setup unless you're running into detonation, or have built extra compression into the engine. Advancing timing beyond 22 degrees may not increase power. It's an efficient combustion chamber, doesn't need as much advance as some other engines, and there's no benefit beyond a certain point.
Maybe the e85 needed more electrolytes. (Brawndo reference)
