NEED HELP Quick! Brake Booster.......
Old May 20, 2010 | 06:19 PM
adrian951's Avatar
adrian951
Default NEED HELP Quick! Brake Booster.......
I just changed my brake booster on my 2001 due to the TSB on a weak return spring. Now my brake pedal goes to the floor when the car isn't even on with no vacuum. Does anyone know what this could be?
I have a track day tomorrow which I'm leaving for at 4 am. I'm here the whole time. Anyone have any input??????
Old May 20, 2010 | 06:22 PM
lucky131969's Avatar
lucky131969
explain exactly what you did......
Old May 21, 2010 | 12:08 AM
ref772's Avatar
ref772
There is no lost travel inside a booster. You could replace the booster with a broom handle and it would have the same problem. You just have to push harder. If you push the pedal in 1/16", the m/c piston moves 1/16". All the booster does is assist. You probably have air in the m/c. I assume the overall distance from the pedal mount to the end of the m/c pushrod is the same as the old booster.
Old May 21, 2010 | 12:16 AM
TEXHAWK0's Avatar
TEXHAWK0
Did you remove the brake lines from the master cylinder to do the work?
IF so, I agree you need to bleed the M/C first.
Old May 21, 2010 | 10:33 PM
adrian951's Avatar
adrian951
Fixed it. Sorry for late reply. Did something very stupid. lol
Old May 21, 2010 | 11:01 PM
byronhunter's Avatar
byronhunter
We sure did get a good explanation!!!!!!!!!!!!!!!!
To NEED HELP Quick! Brake Booster.......
