having electric QTP cutouts problem
Old May 22, 2010 | 07:04 AM
baezi z06's Avatar
baezi z06
Default having electric QTP cutouts problem
hi
i´m running new dual QTP 3" cutouts on my Vette running few months and it has been no problem, but then one time after i opened it, the light on the switch went off and the fuse wire was burnt a bit but not torn apart, but i installed new fuse, and the light came on..... but as soon as i tried to close the damn thing the light went off... so what can this be?
please let me know what you think
hope the motors are not destroyed on a new kit.....
thanks
Baezi
Old May 22, 2010 | 11:05 AM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
first guess would be direct short in the wiring to the motor(s) look for a spot where the wires may have rubbed on the frame or other ground spot. hope it's simple.
Old May 22, 2010 | 11:15 AM
rebelheart's Avatar
rebelheart
Sounds like a short to me also,I would look around the hot exhaust pipes first. Disconnect the cut out motors one at a time to see which may be shorted,if the short remains after both are disconnected then you know the short is in the wiring.
Old May 22, 2010 | 01:14 PM
baezi z06's Avatar
baezi z06
i was reading on the new fuses i got 1 amp , would you not say it was to small for these two rotors....
will take a looke under the car this weekend... see what i going on.
b.w. í´m using the cigarrette lighter electric wires..
thanks
baezi
Old May 22, 2010 | 01:27 PM
Jnape's Avatar
Jnape
thanks
baezi
Fuses are used to protect the wiring not the motors. If you used the cig lighter ciruit I would replace it with the stock amperage fuse. Not sure but probably a 10 amp?
Old May 22, 2010 | 04:25 PM
rebelheart's Avatar
rebelheart
Yes,a 1 amp fuse would be to small for the amps these motors will require.
To having electric QTP cutouts problem
