2001 6speed problem
Old May 23, 2010 | 04:30 PM
PEPPI5's Avatar
PEPPI5
6th Gear
Default 2001 6speed problem
My car grinds and pops out of reverse but its not a linkage prob any ideas
Old May 23, 2010 | 09:03 PM
Oldvetter's Avatar
Oldvetter
Can't hurt to change the trans fluid.
Old May 23, 2010 | 11:38 PM
ragtopws6's Avatar
ragtopws6
The reverse gear has a bronze blocking ring and doesn't do a very good job matching the speed before being engaged. If you don't come to a full stop and try to shift it into reverse sometimes it grinds a little. Well, that over time leads to rounded engagement teeth. It's gets worse from there.
To answer your question, you most likely have a broken plastic fork pad that is not engaging the synchro into gear all the way. This in turn, "pops" out of gear and will not stay in.
The first 2 pics shows the rounded off teeth. The third pic shows broken fork pad still installed in the synchro.
To 2001 6speed problem
