Looking for advice on my "new" wrong RPM diff?
Old May 24, 2010 | 02:27 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by Slowhawk
no calibration needed (for rear axle ratio change). Only changes are used for tire sizes.
ding... ding... ding; we have a winner !
Old May 24, 2010 | 03:18 PM
Ksths2's Avatar
Ksths2
Wow lots of posts! - I never slammed RPM, I was just saying if i come to the conclusion that it does have the wrong ratio then i'll be pissed, anyway.
I called TJ at RPM and he said the samething that the Vettes don't need to be callibrated so thats solved, he also said i am correct about the rpms are 3400 in 4th and i now need to do a test in my dads stock 3.42 C5, it should be about 3000 at 70 in 4th. So it looks like i might have a 3.90 after all. He said when we did the test in 6th at 70 it'd be very hard to see any rpm difference cuz of the amount of overdrive in our cars.
I'll give it a whirl tonight and i'll report back. Thanks!
Old May 24, 2010 | 03:26 PM
lucky131969's Avatar
lucky131969
Originally Posted by Ksths2
Wow lots of posts! - I never slammed RPM, I was just saying if i come to the conclusion that it does have the wrong ratio then i'll be pissed......
In there in lies the problem. You have not yet reached ANY conclusion...and your first step was to create this thread...not even calling RPM first. Brilliant !
Old May 24, 2010 | 05:30 PM
slow ride's Avatar
slow ride
Thats not right as I've had both a m12 and m6 in my z with 3.90's and it's 2000 vs 1800. It's fairly easy to tell. We had the same mixup on the dyno with my car and the 3.90's. Best thing to do is leave it on the 3.42 gear size and adjust the tire size (if you run something other than stock) till the speedo matches the dyno speed.
Old May 24, 2010 | 09:07 PM
Ksths2's Avatar
Ksths2
Here's the deal, its a 3.90 I did the test that RPM suggested in 4th gear and did the same to my dads and mine is 3400 at 70 and his is 3100 at 70 so we are good to go..... I'm calling RPM tomorrow and telling them there are no problems just a little confusion. I'm extremely relieved now.
Either way thanks to the ones that was helping me diagnose the issues even though it looks like its caused more issues than solved for some..... sorry to get anyone wound up!
Case closed
Old May 24, 2010 | 11:00 PM
ncvettes's Avatar
ncvettes
Doesn't take much to wind these guys up as their histories will show. Glad you got it figured out.
Old May 25, 2010 | 05:29 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Originally Posted by postwhore
I thought is was the wheel sensors ?
The wheel sensors are for active handling, traction control and the ABS braking system.
Old May 25, 2010 | 05:32 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Case closed
No one is really wound up, it's how you phrase your words that incite others responses to you.
Just thing about what you're saying or writing.
I'm glad you got it all sorted out.
Old May 25, 2010 | 08:42 AM
Chicago1's Avatar
Chicago1
For future reference
Old May 25, 2010 | 09:24 AM
CTD's Avatar
CTD
If HPT was used for calibrating it will changed the speedo when doing the new gear calculations.
You just have to change the speedo back to it's original number.
That has caught many of us.
