TNT NITROUS INSTALL IS DONE! ... FINALLY! :)
How did you mount your blow down tube?
-Tuan
So if there is anything that needed to be upgraded first, it would be the fuel pump before the injectors.
:cheers:
-Tuan
[Modified by bwhitmore, 4:42 PM 3/19/2002]
Running a big hp-shot on a wet system, if you are not getting enough fuel flow and pressure from the line, IT WILL RUN LEAN no matter how big your fuel injectors are. The fuel injectors are control by the PCM so it will not know when you are running nitrous and when you are not, let alone knowing how big of a shot you're running.
:cheers:
-Tuan
:cheers:
-Tuan
-Tuan
I threw out the blowdown tube that came with the kit. It wouldn't work with the bottle in that spot. I have a really big braided line that runs out below the car. You can see it in the pic.
[Modified by PHAT CHANCE, 5:40 PM 3/19/2002]
This rain up here is driving me nuts though!.. I need another race!! ;)
In my experience I would say the injector size is the biggest limiting factor to not running a 150hp shot. In the earlier C5's, 97-98, the injectors where larger, as was the case with the F-bodies. On my 98 WS6 I ran a 150hp shot only because I felt safer with the larger injectors. I monitored my fuel pressure always, and utilized a Fuel Pressure Safety Switch.
I believe if you want to run a 150hp TNT kit, you should consider changing your injectors and use a MAFT to tune this set up properly. Getting a MAFT will allow you to trick the computer and allow more fuel into the system when running nitrous. The bigger injectors just allow you to maximize the amount you inject. The nice thing about a MAFT is it will let you recalibrate this system at the times in which you are not running nitrous so that you do not experience a rich condition at these times.
The high flow fuel pump is nice, but it is not going to do much for you unless your injectors meet the amount of added fuel being pumped to them. And the regulators are only available for the earlier model C5's anyway.
My last suggestion would be to pick up AutoTap or go get your air/fuel monitored by a local dyno shop so that you cantune the MAFt accordingly. The little autometer air/fuel gauge like I run is cool looking, but I don't trust it for it's accuracy.
[Modified by Skeeter1, 11:10 PM 3/19/2002]
[Modified by PHAT CHANCE, 4:27 PM 3/19/2002]
LS1 fuel pump and injectors will handle 150 RWHP shot of N20:)
What I have read on other forums. Problem with TNT kits are, TNT underates RWHP numbers, for marketing purposes:( Underating RWHP numbers makes TNT kits look like they are producing more RWHP from their kits, but in fact TNT is just jetting more N20 into their kits.
So if you buy a 150 RWHP from TNT, you may dyno 180 RWHP, as TNT kit is adding more N20 to produce the extra RWHP number:(
[Modified by jetskifast, 10:56 PM 3/19/2002]
Why did you have your solenoids mounted right in the middle of all your engine heat :confused:
Solenoid failure is your major concern with any N20 system.
Heating and cooling of solenoids over time will cause failure on a steet car.
Mounted my solenoids on front frame member, away from engine heat :cheers:
I'm not sure how much heat these solenoids can take, but one thing for sure....I wouldn't want to test it on my car. :D
-Tuan
I'm much more concerned about what shot size I can run safely with a stock fuel pump.
Besides when the engine does go, either from mileage or from NO2, then it's just a nice excuse to get a 427 C5R block! :lol: :lol:
[Modified by oceanaire, 1:31 PM 3/20/2002]
Besides, I can always just leave the TNT stuff on and hook it up to the 427 :D
I'm beginning to think I need to check myself into "mod addicts anonymous"!!
:rolleyes:
[Modified by PHAT CHANCE, 12:54 PM 3/20/2002]
bwhitemore
the stock ls1 fuel pump WILL NOT HANDLE A TNT 150
shot.
[Modified by Skeeter1, 4:21 PM 3/20/2002]
The larger injectors are proven to run fine under normal operating conditions (ie, factory fuel pumps, and fuel regulators) as long as the computer is tuned accordingly. I ran 36# injectors, a MAFT, and a 150hp TNT power ring system on my '98 WS6. I never upgraded my fuel pump, nor did I make any changes to the regulation of my fuel pressure in some 25,000 miles. The car still runs strong today at over 75,000 total miles (with the exception of modifying the transmission and a couple sets of tires). I doubt seriously the fuel pump in it was any different if not less than what is run in my Z06 from the factory.
Also, the assumption that the TNT 150hp kit pulls close to 180rwhp is a little far fetched. It seems the Crank and Chrome episode has done more than wet our tongues. In my experience the other kits are under rated, but to say the TNT kit is over rated is going to far. I have no dyno numbers to suggest that the TNT kits push anything else than pretty close to exactly what they claim. Don't let the graphics fool you, this is my second TNT 150hp kit.... I think I have some experience with them.
[Modified by bwhitmore, 2:38 PM 3/20/2002]
Hmmm.. I want to run the 150, I want make sure it's safe, but I also don't want to get ripped off for a new fuel pump if I don't need it. :confused:
Where did you get that blue fitting that connects to where the blow down tube would be? Is that a NPT to 6AN fitting?
-Tuan
