This is udderly ridiculous! All I needed was a little help...and I don't really think this missing udder is the cause my leak, but I like to be udderly stock as far as possible. Thanks for the suckjestions!
Good luck with vette2vette. I purchased a part from them and needed to return the part and i called and left voice mails and he woul dnot answer or return my phone calls. Also I tried to return the package and he will not accept the package so be careful.
The windshield cowl drains have rubber deflectors in the drain holes to direct the water straight down and to help keep rodents out (even-though they still get in the cowl area with the udders in place ) If they plug and that cowl can not drain, it will destroy your wiper motor module on the bottom of the wiper motor!
There GREAT till they plug with trash. Heres shot of the udders on the drivers side cowl with the fender removed:
You can reach them easily from here:
Heres a pic of the PASSENGER SIDE drain tube:
I would not remove it cause its a royal pain to get it back in place properly. Just flush it with a hose!
Heres some YUMMY stuff that collects inside the udders.
