I changed my trans fluid to Amsoil TDS a couple days ago. I changed the gear fluid out to Amsoil Sever Gear while I was at it. I no longer get any backlash and the shifter slips right into gear. The transmission also is a bit quieter... When in mid-down-shift I no longer hear the gears syncing up. No winding noise.
