Can C5 springs settle.....
Old May 27, 2010 | 03:20 PM
PetersC5's Avatar
PetersC5
Default Can C5 springs settle.....
I'm the second owner of a 2000, 25K mile C5 convertible with stock FE1 suspension. The 65 year old first owner insists that the car has never been lowered.
Per the GM manuals trim height inspection procedure (suspension 3-16), the car should measure 6.02" (153mm) for the J height and 6.22" (158mm) for the K height at the prescribed measurement points.
The car is lower, by just about 3/4", 18mm to be exact.
The height isnt an issue but I hought these composite springs couldnt settle??
I'm concerned because the FE1 is kinda soft anyway, ive just upgraded to C6Z51 bars and plan to do the C6Z06 shocks but now i am wondering if the springs themselves arent bad
All thoughts appreciated
Old May 27, 2010 | 03:30 PM
SaberD's Avatar
SaberD
the springs will not creep. if the car is actually lower, i would check to make sure the bushings for the spring bolts arent smashed. also check for delaminating in the spring.
Old May 27, 2010 | 03:36 PM
PetersC5's Avatar
PetersC5
Saber
Although I haven't pulled the bushings, did look at them and they appear to be fine but i dont have anything to measure them against.
the 18mm drop is perfectly even front and rear, and the car is dead level side to side. that why i questioned the springs setteling or creep as you say.
Old May 27, 2010 | 03:56 PM
SaberD's Avatar
SaberD
are your tires 245/45/17 front and 275/40/18 rear? 30 psi all around?
Old May 27, 2010 | 04:07 PM
PetersC5's Avatar
PetersC5
Yes, the tires are GY run flats 245/45/17 and 275/40/18 with 8000 mile on them. its a dead stock car with the exception of the C6Z51 bars and metal end links i just added.
I'm an ex auto mechanic and although 60yrs, everthing looks as i would expect, not squashed bushings, spring mounts look normal etc.
Old May 27, 2010 | 04:18 PM
SaberD's Avatar
SaberD
maybe the guy you bought it from was senile . im willing to bet its lowered. maybe some others can chime in with possible causes.
Old May 27, 2010 | 04:29 PM
socalman's Avatar
socalman
St. Jude Donor '10
what's the height, ground to fender (front and rear)
Old May 27, 2010 | 04:33 PM
wcsinx's Avatar
wcsinx
10 year old rubber spring bushings will have collapsed a little I'd think. Prob. wouldn't be apparent unless you viewed them side-by-side with a new one.
Old May 27, 2010 | 04:41 PM
PetersC5's Avatar
PetersC5
Socialman
a quick fender measurement at wheel center to bottom of lip in the driveway is
LF=27-3/16" RF=27-1/4" LR=28-5/8", RR=28-3/4
Old May 27, 2010 | 05:34 PM
socalman's Avatar
socalman
St. Jude Donor '10
Originally Posted by PetersC5
Socialman
Out of a good handfull of stock C5s I measured, the average, within 1/4" was
front 27.5; Rear 28-3/4. Looks like you're about normal. Springs usually don't fade, but rubber does.
The rears have rubber bushings on top of bolt and under at nut.
Fronts have rubber bushing under the adjusting bolts, and they do 'mush' after a while. When I removed mine, the right front was smashed in half.
So, I'd say you're not lowered, but basic rubber aging
Old May 28, 2010 | 05:39 AM
clif's Avatar
clif
St. Jude Donor '09-'10
On my 99, my front spring had fatigued. It was lower that stock. I finally replaced both springs with Pfadt coil overs. No looking back now, I love this suspension!
Old May 28, 2010 | 09:53 AM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Socialman
I just lowered mine last week and those measurements look like my 'before" measurements. I'll double check tonight and report back if I am mistaken.
edit: this is on my 00 with 54k miles
Old May 28, 2010 | 10:46 AM
PetersC5's Avatar
PetersC5
Thanks for all the help, ideas and advice, its appreciated...
I just looked in the GM manual and it lists a specification for the front Spring Adjuster Bolt Gap of 2 to 24mm (this is the thread showing between the bottom of the springs washer and the top of the bushing) and in the rear, they call out a Rear Spring Stud Height (total length of bolt above the nut) of 22mm to 46mm. the only thing they dont state is "what is the factory" setting....
I just measured my car and I am at 14.5mm in the front and 40mm in the rear. I dont know what it is supposed to be??
Anyone have a stock height C5 Vert that can measure theirs or has anyone recorded what the stock gaps are supposed to be??
Old May 28, 2010 | 05:23 PM
lionelhutz's Avatar
lionelhutz
Most lowered cars end up with almost no space in the front and the nut almost right at the end of the bolt in the rear.
I'm not really sure what your problem is. It sounds pretty much stock to me. Does the ride height not suit? Does it not drive OK?
Do you have a fair bit more gap over the top of the wheels than in front of and behind the wheels?
Peter
Old Jun 1, 2010 | 12:05 PM
PetersC5's Avatar
PetersC5
Thanks for all the thoughts....was away for the holiday...
The car is fine, i have no issues but I am trying to figure out if indeed the springs have sagged on the car. I'm upgrading the FE1 suspension slowly, the new C6Z51 bars are an amazing difference and I plan to do the c6Z06 shocks next.
My concern is if the FE1 springs are sagging should I upgrade them to C5Z51 springs or am I chasing a ghost .....
I tried the dealer but they can only recite whats in my manuals, they cant tell me what the front adjuster bolt gap or the rear stud height is set at from the factory.
Old Jun 2, 2010 | 09:40 AM
RSchleder's Avatar
RSchleder
Peter, I'm not sure why you'd consider changing the springs when you're ride height is right where it should be. Maybe I'd consider new bushing ( if they look visibly smashed) but not even sure I'd do that assuming they have their original shape.
Old Jun 2, 2010 | 09:56 AM
PetersC5's Avatar
PetersC5
My bushings are fine.....
Per the Y2K GM manuals trim height inspection procedure (suspension 3-16), the car should measure 6.02" (153mm) for the front J height and 6.22" (158mm) for the rear K height at the prescribed measurement points, 35" back of frt wheel and 31" in frt of rear wheel.
My car is 18mm lower than these stock heights stated in the manual, 135mm front, 140mm in the rear. It is an unlowered car so the only thing that can account for an 18mm drop is spring sag, again, all bushings look like new. maybe 1~2mm out of the bushings from age.
The car being lower is fine, i have no issue other than trying to find out why its lower. Its 2000 with 25k miles and I am trying to figure out if the springs are begining to sag with age. Spring sag is mentioned in the GM manual but not in detail.
To Can C5 springs settle.....
