What Amsoil Oil do you use ?
Old May 27, 2010 | 07:16 PM
BLKOHZ06's Avatar
BLKOHZ06
Default What Amsoil Oil do you use ?
The original owner of my head/cam Z06 used 5w-40 auropean and that is what is still in the car. I put probably 3000 miles on it so far and it seems to really like that oil but there are so many other types like 0-30 signature series and 5w-30 and probably more. 5w-40 was really popular a while back but I dont see many using it now. Just thinking about a change. I have 2 qts of the 5w-40 still that I need to use up.
Old May 27, 2010 | 09:05 PM
thechosenone's Avatar
thechosenone
0w-30 and I love it!
Old May 27, 2010 | 09:34 PM
LoneStarFRC's Avatar
LoneStarFRC
0w-30
Old May 27, 2010 | 10:21 PM
BLKOHZ06's Avatar
BLKOHZ06
looks like I might have to give 0w-30 a try. I should probably just stay with what works right ?
Old May 28, 2010 | 05:36 AM
vettenuts's Avatar
vettenuts
When I run Amsoil, I run the 5W-30 ASL.
Old May 28, 2010 | 07:38 AM
BLKOHZ06's Avatar
BLKOHZ06
ok what is the difference between the 0w-30 signature and the 5w-30 asl. Is there just one type of both. I know the first number is just for cold start up and they are both 30 weight oils but what does the asl and sso stand for ?
Old May 31, 2010 | 08:29 PM
Navy Blue 210's Avatar
Navy Blue 210
Default Amsoil sso 0w-30
I use Amsoil SSO 0w-30 in my 99 w/137kmiles. I believe SSO stands
for Signature Series Oil since the company founder Al Amatuzio
puts his signature on the bottle.It is Amsoils most technically advanced
oil for modern cars. I have used it since it first came out, 1997 I believe.
If you have high consumption,or open track alot I would recommend
5w-30 or the 5w-40 Euro.On the street with a tightly sealed motor
SSO is the best you can use.
At the track w/out cats RD30 10w-30 Race Oil w/ 1600+ ppm zinc &
phosperous.
Old May 31, 2010 | 11:09 PM
waddisme's Avatar
waddisme
I use the 20-50 for mine seeing it is tracked. If you go to ax/road racing section and search for "subdriver", he is the forum AMSOIL rep and recommend the best oil for your needs. He suggested the 20-50 for me because I do dd also so I would need something with some detergents. Give him a buzz. They were running a special.
Old Jun 1, 2010 | 01:18 PM
bluewire's Avatar
bluewire
Active Streak: 90 Days
I use the 0w-30 in mine. It's a great oil, I notice better pressure at idle as well.
Old Jun 2, 2010 | 05:58 AM
hobbesnmina2001's Avatar
hobbesnmina2001
St. Jude Donor '10-'11-'12,'14
Amsoil 0w-30 on the Z06, 5w-30 on other street vehicles. 20w-50 for racing w/alky motors.
Torque Drive in trans and Severe gear 75w-90 in Z06
Universal ATF in other street vehicles Severe Gear 75w-90. 75w-110 in 2500 HD.
Super shift ATF for racing.
To What Amsoil Oil do you use ?
