Headlight problem
Old May 27, 2010 | 07:51 PM
Brock Samson's Avatar
Brock Samson
Default Headlight problem
My headlight is acting up. When I turn off the lights the one light goes down and up repeatedly. Sometimes it stays up, sometimes it goes all the way down. Any thoughts before I take it to the dealer?
Old May 27, 2010 | 08:15 PM
BCC5's Avatar
BCC5
Default hea
a couple of years ago I had problems with one of my headlights not always opening on my 99 coupe.
after some questions on this forum I was directed to a guy who specializes in GTO parts, but makes brass replacement gears for Corvette headlights.
I only needed the one but bought both and installed them (easily)..45 minutes - an hour each. They have worked flawlessly since.
don't remember the guy/company but found it through this forum
good luck
Old May 27, 2010 | 11:15 PM
martinsw's Avatar
martinsw
Just had the problem with my passenger side headlight also.
Replaced with the metal gear from below link - only took 20min or so, working great!
http://www.bfranker.badz28.com/headlightfix/
Old May 27, 2010 | 11:19 PM
byronhunter's Avatar
byronhunter
Now that dosn't sound like the Striped Gear problem. Is it the Driver's side?
Old May 27, 2010 | 11:25 PM
byronhunter
If it is the Driver's side, this is probably what you need.
Here's the TSB:
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition: Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment
that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number Description Qty Per Vehicle
11505463 Washer 3
16524060 Insulator 2
Old Jun 1, 2010 | 03:09 PM
Brock Samson
Here's the TSB:
Correction
Important
Parts Information
11505463 Washer 3
Thanks, that is exactly what the problem is.
Old Jun 1, 2010 | 04:13 PM
byronhunter
Old Jun 1, 2010 | 05:23 PM
Chicago1's Avatar
Chicago1
The stops are discontinued I had the same issue and went to my dealer. They are about $7 each and when he ordered them he said they are no longer made. I just used the other one and flipped the broken one down untill I order some from somewhere.
To Headlight problem
