Floor Jack Problem
Old May 28, 2010 | 09:14 PM
Nick1's Avatar
Nick1
Default Floor Jack Problem
I have a pretty good floor jack, but noticed that it wouldn't get it up all the way recently! I figured that it needed oil although I havn't noticed any leaks. Had it about 7 years. I have heard of "jack oil", but heck who has some laying around when you need it?? In any case, I added some brake fluid and all seems well. Is this a potential problem? What's the difference?? Thanks!
Old May 28, 2010 | 09:17 PM
FirethornC5's Avatar
FirethornC5
Brake fluid will ruin the seals and the jack could potentially fail. You must use Hydraulic Jack Oil that can be purchased at any auto parts store.
Old May 29, 2010 | 09:57 AM
postwhore's Avatar
postwhore
I've used a little brake fluid to soften the seals on a leaking jack .
I wouldn't think of it as a permanent fix though.
Generally speaking , ATF is a better choice if hydraulic fluid is not available.
Brake fluid is not a good choice
Old May 29, 2010 | 10:08 AM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Tried Viagra, I assume. JK- go with the jack oil, for sure...
Old May 29, 2010 | 03:21 PM
Nick1's Avatar
Nick1
Right thanks! I will get the proper fluid, although I can undstand why ther is a diffenence in the effect on seals. There are seals in a brake system too for instance. Right?
To Floor Jack Problem
