rear gear ratios ?
Old May 29, 2010 | 09:27 PM
Spartan 45's Avatar
Spartan 45
Default gears
I think I will go with the 3.42. Now I will have to watch the forum, corvette recyclers, and Ebay to find the right one. Thanks for all of the responses
Old May 31, 2010 | 09:07 AM
RSchleder's Avatar
RSchleder
Don't forget to have your shift points reprogrammed.
Old May 31, 2010 | 02:20 PM
tsts's Avatar
tsts
Ditto that, very important!
Old May 31, 2010 | 07:38 PM
mitchell c's Avatar
mitchell c
If your going to the trouble swapping gears. Also swap the low stalling stock converter while your car is apart. A hi stall T/C like the Yank SS3200 or SS3600 will make a HUGE difference in performance. Excluding nitrous a hi stall T/C is the most bang for the buck in an A4.
Old May 31, 2010 | 08:43 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
I have RPM 3:42's, RPM Level IV Transmission & a Yank SS3200. Car has great street manners and yet when you step on it it's like lighting a rocket!
Old Jun 1, 2010 | 04:34 PM
retired cop's Avatar
retired cop
Anyone here went from a 2.73 to a 3.42 and picked up at least 3 tenths?
Old Jun 1, 2010 | 06:12 PM
rboineau's Avatar
rboineau
A stock 2.73 auto is a hopeless slug. Before I learned anything about C5s, I rode in a pristine auto C5 and it was so slow I truly thought something was wrong with it. That same car later had a 3.42 gear put in it with requisite tuning, nothing else done, and I could hardly believe it was the same car. Before the gear swap, I raced him with my newly-acquired C5 manual and walked away from him. After the swap he could usually beat me, 'tho it was more a case of me struggling with that miserable C5 manual shifting than his car actually being quicker--when I did manage to hit the gears right I could edge him out.
Old Jun 1, 2010 | 07:22 PM
retired cop
Thanks for the post and I believe you. I dont want to spend two grand for just 2 tenths.
Old Jun 1, 2010 | 07:24 PM
retired cop
By the way I recently had mine tuned and it was noticably faster maybe it was his tune?
Old Jun 1, 2010 | 08:38 PM
RDKING's Avatar
RDKING
Originally Posted by Bluefire
With that said, I think the 3:42 is the perfect choice for you. You may lose 2 - 3 mpg (city), negligeable (hwy). That is what I experienced when I did mine. I also added a mild Yank 2800 stall converter just for that extra little kick in the *** on "take-offs".
with Bluefire
Old Jun 2, 2010 | 02:24 PM
Bluefire's Avatar
Bluefire
I do understand your reasoning for not doing it. I will add though that the extra torque that you'll get from the 3:42's can be enjoyed when leaving every stop, not just the strip.
Old Jun 2, 2010 | 02:45 PM
2000BSME's Avatar
2000BSME
I got a 3.42, and I really wish I'd gone with a 3.73, but they weren't immediately available.
Old Jun 2, 2010 | 02:48 PM
  #33
2000BSME's Avatar
2000BSME
I highly doubt it.
Old Jun 2, 2010 | 08:00 PM
  #34
Spartan 45's Avatar
Spartan 45
Default gears
I thought my 97 came with a 2800 stall in it. I have to decide on putting a 3200 stall in while I have it apart for the rear.
Old Jun 3, 2010 | 09:44 AM
  #35
mitchell c's Avatar
mitchell c
The stock T/C is only 1300 stall speed, and is the biggest reason stock C5 A4s don't perform as they should . Go with at least the Yank SS3200.
Old Jun 3, 2010 | 09:59 PM
  #36
Mike Mercury's Avatar
Mike Mercury
inexpensive "one notch up" TC upgrade that doesn't require an added cooler:
http://forums.corvetteforum.com/c5-t...-da-floor.html
Old Jun 6, 2010 | 01:37 PM
  #37
Spartan 45's Avatar
Spartan 45
Default torque converter GM
Thanks again for the information. I found the part on GM Parts House. I like your suggestion. That's what I will do with mine next. I will keep you posted on the result.
