From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Need Help With A Warning Light
The low washer fluid warning light came on the other day and when I checked the fluid level it was low. I filled it up with fluid and the warning keeps re-appearing every time I start the car. I rechecked the fluid thinking I may have a leak, however it is still full.
I can get rid of the message by pressing reset, however it keeps coming back.
the little sensor that reads washer fluid levels gets corroded with water deposits--It is propbably stuck--- try taking it out and cleaning with some simple green or something else to break up the corrosion-
St. Jude Donor '12
Thanks folks, I'm out of town traveling, but will take a look when I get home tomorrow. If it's corrosion and cleaning it fixes it then great. Not sure I'm ready to spend $90 if cleaning doesn't solve the problem
