I've got a 2002 (5,000 miles) automatic with the dreaded small vacuum leak code. I've messed with the gas cap, looked fine but replaced it anyway. No good,...code returned. I decided to order a vapor canister purge valve and replace it on the next rainy day. Well, only problem is I can't seem to locate the valve on the car. Can someone point me in the right direction as to where I might find it. If I can't see it easily, I'm guessing it's not a simple swap out,....can anyone comment on the change out process?
Sorry Waddisme,
I haven't gotten around to swapping out the valve yet. I can say the code however does not appear to effect my engine performance. I'm pretty sure my leak is on the fuel tank side, and not in the engine bay.
check under drivers side fuel rail cover...there is a small EVAP hose connection that may have worked loose or is cracked....that was the source when I got this P0442 code
