Well this sucks...
Old Jun 5, 2010 | 09:40 AM
SargeZ06's Avatar
SargeZ06
Default Well this sucks...
Kooks 1 7/8 w/3' collector.
Now minus the AIR tube...
Old Jun 5, 2010 | 09:55 AM
tramminc's Avatar
tramminc
weld a plate over it.
Old Jun 5, 2010 | 03:40 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
You could have a good welder weld the tube back on. I have seen this happen a few times on various header brands.
Old Jun 5, 2010 | 04:28 PM
bumble-z's Avatar
bumble-z
Notify Mr Kook's. I'm sure he will make things right for you in regards of a replacement/repair of header. Good luck.
Old Jun 5, 2010 | 06:18 PM
zeevette's Avatar
zeevette
Time to ditch the air pump, and it's system of hoses.
Old Jun 5, 2010 | 10:16 PM
SargeZ06's Avatar
SargeZ06
It was already gone. Air tube was capped off.
Old Jun 5, 2010 | 10:33 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Now is a good time to have a nice plate welded on.
Old Jun 5, 2010 | 10:37 PM
SargeZ06's Avatar
SargeZ06
Yeah just as soon as I can get the freakin header out I will. Damn Kooks are heel to get out. I think I'm going to have to pull my FAST intake in order to get the engine up high enough to get the driver side out. Spent about 4 hours on it today.
Old Jun 5, 2010 | 11:09 PM
Mr.Bill's Avatar
Mr.Bill
I have seen some great welders, I bet it can be done on the car?
Old Jun 6, 2010 | 01:12 AM
SargeZ06's Avatar
SargeZ06
Well intake off and another 2 hours wasted and Driver side still not out. ugggghhhhhh!!!!!!
Old Jun 6, 2010 | 07:46 AM
Blow Torch's Avatar
Blow Torch
Like Mr B said; It CAN be done on the car by a good welder
Old Jun 6, 2010 | 09:26 AM
jrose7004's Avatar
jrose7004
You're right, it does suck!
Old Jun 6, 2010 | 09:42 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
Thats why it broke off. To much vibration and once its capped off there is no support left. It can be patched, its not Kooks fault at all, most of them will do the same thing. There is a lot of weight hanging and after time the vibrations are just to much for it to handle.
Old Jun 6, 2010 | 09:45 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It can be fixed - it will be a little noisey but get it to the muffler shop and have the fella's weld it up!
Not as bad as I thought it'd be!
Let us know how it goes
Thanks,matt
Old Jun 6, 2010 | 10:18 AM
SargeZ06's Avatar
SargeZ06
what are people using for a leverage point to pry the motor over? Frame and alt. bracket? Are they pushing the toward the motor with the top of the 2x4 with the bottom of it pushing against the frame rail?
Just about ready to SawZalll the damn primaries and buy something else.
And to take it to a welder I would have to try and get a trailer. I'm out in the country and not many mobile welding services out here.
Old Jun 6, 2010 | 10:38 AM
bumble-z's Avatar
bumble-z
That is the Dr side your working on correct?
Old Jun 6, 2010 | 10:40 AM
Mr.Bill's Avatar
Mr.Bill
Even getting a trailer would be a lot better than what you are going through, After you get it out you still have to get it back in, That is an easy in car fix for sure. Maybe take 10 mins.
To Well this sucks...
Old Jun 6, 2010 | 10:45 AM
SargeZ06's Avatar
SargeZ06
HA HA HA HA HA HA HA HA HA
I got the damn thing out. I went to the country lumber store and bought a 3' Hickory pick handle. Pushes with my left hand and lifter the header with my right. Came right out.
I don't know whether to beat the crap out of it with the pick handle or take it and get it fixed.
I think I'd enjoy beating it to scrap metal more...
Thanks for all the advice. Journey is half over. Still gotta get it back in...
Old Jun 6, 2010 | 12:07 PM
99blancoss's Avatar
099blancoss
Former Vendor
Well considring it a 400+ header I might have it fixed..LOL Congrats on the removal
Old Jun 6, 2010 | 12:19 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Good to hear you removed it for the weld job or are you just going to replace it? To weld it properly the inside of the run being welded needs to be purged with argon during the welding. I hope the weld and reinstall goes well.
