Calif smog test info?
Well now i have to do it again..ok the only thing i worry about, is that back then when i went and had it done the (NO PPM) reading were High to me like 236 at 15mph and 77 at 25 mph..Now since then i have not put more than about 2,000 miles on it.
And i know with the NO PPM that high they always say its the cats.well i cant afford to buy new cats at this time..And i have to get it tested soon.. So is their any thing that i can buy at the store for now that might lower this reading?
If you know any thing i can try that is not dumb..pleas let me know ok..And yes since then i have done new wire's and plugs, And a oil change, and that was all done in the last few months. Some feed back on this would be so nice.
Thanks dbiddle.
http://www.sme044.org/smogresults.jpg
Converters don't last forever, but pretty close. If you do need to replace converters you might find some off a car that's being parted out.
Also, run your car semi hard for about 30 minutes before going in, get on a freeway or best thing is to climb some hills if you have any near you. It gets the cats good and hot, they test better. Had a tech tell me this on our 96 bmw after pre testing-had me leave his shop, go cruise up the local hills, climb and punch it as much as possible for 1/2 hour- came back and it passed.
