Need FIX for creaking windows...
Old Mar 20, 2002 | 02:22 AM
Viprklr's Avatar
Viprklr
Default Need FIX for creaking windows...
Hey everyone. Both windows on my hardtop have begun making noise when you open and close the door. They seem worse since I took the car to the body shop. :confused: They didn't have to remove the door, so I am not sure why that is the case. Maybe one of the techs hit the door getting in and out??? Anyway, is there a way to tighten the glass? I remember a post a while back about adjusting the window to tip in or out. Not sure if that would be helpful in may case. Anybody out there done it, or is it time for a dealer visit (gonna go for an alignment anyway)? Thanks all!
:cheers:
Matt
Old Mar 20, 2002 | 11:02 PM
bparker's Avatar
bparker
Default Re: Need FIX for creaking windows... (Viprklr)
[Modified by bparker, 7:27 PM 3/22/2002]
Old Mar 20, 2002 | 11:12 PM
C5Noir's Avatar
C5Noir
Mine does the exact same and it drives me nuts! It makes jiggle sound when I open the door :mad
Old Mar 21, 2002 | 01:32 AM
Viprklr's Avatar
Viprklr
Default Re: Need FIX for creaking windows... (C5Noir)
Somebody must have a fix for this??? Please help. :crazy:
Old Mar 21, 2002 | 08:35 PM
Viprklr's Avatar
Viprklr
ttt - Wow, I must be only 1 of 3 people who have ever experienced this phenomenon??? This is my last try to get some help. :eek:
Old Mar 21, 2002 | 08:38 PM
jambrin's Avatar
jambrin
You are definetly not the only one with this problem. I have the exact same problem on the driver side. The passenger window is OK as it does not get used a much. It does bug me quite a bit, but I don't think there is any way to fix it. Sorry I am no help :nonod:
Old Mar 21, 2002 | 09:15 PM
Viprklr's Avatar
Viprklr
Default Re: Need FIX for creaking windows... (jambrin)
jambrin - I know that you can adjust the tip in of the window, and wondered if that process would also help to tighten up the glass. :confused:
Old Mar 22, 2002 | 06:12 AM
Blackjetvette97's Avatar
Blackjetvette97
Hi all,
Viprklr, Is it the window that rattles or something inside the door vibrating against the glass? If you go into the door panel(take it off) and look at the window assembly inside, there is a cable which can rub/rattle against the glass when opening/closing the door. I used a cable tie to secure it inside to the door frame, away from the glass, and it seemed to help. I also have this problem of rattly windows, though!
Steve
Old Mar 22, 2002 | 12:44 PM
C5Noir's Avatar
C5Noir
Default Re: Need FIX for creaking windows... (Blackjetvette97)
It's almost as if the windows have worked their way loose and have some play in them where they're mounted to the window rail. I guess we could take a door panel off and look? :confused:
Old Mar 22, 2002 | 01:27 PM
Stunt's Avatar
Stunt
My thoughts exactly! I have the same problem. I can replicate the noise by grapping the top rear corner of the glass with the door open and moving it in and out.
Old Mar 22, 2002 | 09:19 PM
Viprklr's Avatar
Viprklr
Default Re: Need FIX for creaking windows... (Stunt)
Stunt - Sounds like you have my exact problem! :U
If anyone is brave enough to tear their car apart and find a fix that would be cool! I'll keep this post alive so that somebody out there who has done it (hopefully) can chime in. :yesnod:
Old Mar 23, 2002 | 02:03 AM
blader's Avatar
blader
My driver window makes a strong click or tick sound right when the door is opened. It sounds like some play in the glass position. It only started recently and has become very annoying.
-Michael
[Modified by blader, 10:04 PM 3/22/2002]
Old Mar 23, 2002 | 07:57 AM
Gus's Avatar
Gus
Cruise-In III Veteran
I had the same problem! It was like the window was loose. So this is what I did and it took care of that problem... There is a red reflector lens on the lower part of the door. Take a small flat head screwdriver and pop it off from underneath. The you will find a 10mm nut,try thightning that nut and your noise will be all gone :D
Old Mar 23, 2002 | 12:18 PM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
Default Re: Need FIX for creaking windows... (Gus)
Gus,
Thanks for the tip - I'll try the fix today.
My driver side window glass on my 1999 C5 has been making a "knocking" noise when it moves. You can gently rock the top of the glass and it makes the noise.
Thanks again.
1999 White C5 Coupe
Old Mar 23, 2002 | 12:22 PM
C5Noir's Avatar
C5Noir
I just tried it and it didn't alleviate it any :(
Old Mar 23, 2002 | 12:24 PM
shizon'00's Avatar
shizon'00
Default Re: Need FIX for creaking windows... (1999 White C5 Coupe)
Let us know if this worked for you :)
Old Mar 23, 2002 | 01:20 PM
Viprklr's Avatar
Viprklr
Default Re: Need FIX for creaking windows... (shizon'00)
I'll give it a try too. Sounds easy enough. :smash: I'll post back later.
Matt
:cheers:
To Need FIX for creaking windows...
Old Mar 23, 2002 | 01:53 PM
PeterK's Avatar
PeterK
St. Jude Donor '12
2012 Election Contest Winner
Nah, It will not work.
I had a dealer to take it all apart and try to fix that to no avail.
Sorry I think we are all stuck with that.
Old Mar 27, 2002 | 08:22 PM
C5Noir's Avatar
C5Noir
Default Re: Need FIX for creaking windows... (PeterK)
TTT
Old Mar 28, 2002 | 09:15 AM
shizon'00's Avatar
shizon'00
I looked in the service manual and it said that torq screw is to adjust window tip in/out. It has nothing to do with it rattling in the door.
Gotta look somewhere else.
