Clb need clairification please!!!
Old Jun 6, 2010 | 11:46 AM
machz800ps's Avatar
machz800ps
Default Clb need clairification please!!!
I have an 04 z and am ready to install clb from corvettes of houston pulled knee panel and see that the recall was installed by GM one side of the harness has the white wire. i read the CLB THREAD but am unclear DO I INSTALL THE BYPASS or not??
Thank you
Steve
Old Jun 6, 2010 | 11:54 AM
socalman's Avatar
socalman
St. Jude Donor '10
Yes, remove the GM K Harness, install the CLB. You are replacing one for the other. You may have to pull fuse 25 after you are done to clear the system. If you still have the 'wait 10 seconds' scrolling across, then pull fuse 25, wait 10 seconds and re install. (with motor off/ key out).
Old Jun 6, 2010 | 12:10 PM
machz800ps's Avatar
machz800ps
I may be wrong but 04 z only had to be reprogramed dont beleive there is a k harness??
Steve
Old Jun 6, 2010 | 12:25 PM
socalman's Avatar
socalman
St. Jude Donor '10
You said you see the recall was done. If it were only a reprogram, there would be nothing to see. Does it look like this?
http://forums.corvetteforum.com/c5-g...oday-pics.html
Also, look at this- 1st and 3rd posts will tell you what was done and when things changed.
http://forums.corvetteforum.com/c5-t...gm-merged.html
Old Jun 6, 2010 | 01:12 PM
machz800ps's Avatar
machz800ps
Im only saying its done because on the CLB tread it says if you have orange, black, green, and purple wires on the colum side of the harness and white,black,green, and purple on the other side of the conector the recall has been done. maybe 04s allready have this wiring and only needed reprograming. the thread states that 04s only needed to be reprogramed
Steve
Old Jun 6, 2010 | 02:00 PM
machz800ps's Avatar
machz800ps
INSTALLED all set !!!!!
Thanks guys just didnt want to screw something up. went in with no codes or fuses needing to be removed
Steve
To Clb need clairification please!!!
