Horn problem
Old Jun 7, 2010 | 09:59 PM
Nasavette's Avatar
Nasavette
Default Horn problem
My horn does not work when I press the horn butoon on the steering wheel or when I lock with the key fob. The panic button does set off a horn. Is it the sam horn? If so, I checked the fuse and took a relay from another location and tried it but no result. Any ideas?
Old Jun 7, 2010 | 10:13 PM
lucky131969's Avatar
lucky131969
The factory horns are turned on by micro relay #36, which in turn is energized by the steering wheel switch, or the BCM(when locking the car). So if the panic mode works with the factory horn, something does not make sense.
Old Jun 7, 2010 | 11:13 PM
Nasavette's Avatar
Nasavette
I have the lights and horn selected.
Old Jun 8, 2010 | 08:58 PM
ramcharger's Avatar
ramcharger
Use your middle finger instead.
To Horn problem
