O2 codes need serious help
Old Jun 11, 2010 | 09:42 PM
cracker Bear's Avatar
cracker Bear
Default O2 codes need serious help
so i got a 2000 vet just did a motor swap to a ls3.. before i did the swap i was getting codes for o2 sensor heater circut bank 1 sensor 1 and bank 2 sensor 1, also bank 2 sensor 1 no activity.. i figured it just needed new sensors.. i do the motor swap change out o2 sensors and flash computer and they come back so i see that the harnesses got a little melted on the lt's so i replace the harnesess wrap them in heat wrap and make sure they dont hit the exghaust,, they come back again,, i check all the fusess and find a blown on 10amp in the floor board box and the car starts running better but still these three codes keep coming back.. what tha heck ,, i have also checked all the grounds on the frame under the hood and gone so far as to add extra groung straps to all of them off of the body of the altenator and the batt even one directly to the LT's from the engine block,, im loosing my mind trying to figure this out.. its pull the motor out and check every square inch of the wires or replace the computer,, please does some one else have any idea of what could be going on???
Old Jun 11, 2010 | 11:37 PM
byronhunter's Avatar
byronhunter
You might already have this schematic, if not, you need it.
Which fuse did you replace in the IP Fuse Block?
Old Jun 12, 2010 | 01:52 PM
cracker Bear
I don't really remember for sure, I think it was the one labled monitored ld #2 position
Old Jun 12, 2010 | 02:02 PM
lucky131969's Avatar
lucky131969
Ok. Monitored LD is for lighting, and has nothing to do with the O2's. Byronhunter has provided you with a schematic, and you can see that the fuse for the heaters is minifuse # 15 in the underhood fuse box....so that needs to be checked. If you have an inactivity code, and you have a melted harness, then you need to inspect the wiring for shorts/opens. You can also disconnect PCM connector C1, and read the O2 sensor(s) wire resistance, and check for shorting to ground, and each other.
Old Jun 12, 2010 | 02:19 PM
cracker Bear
I replaced the melted harness with a new one and the 15A under the hood is good, so next it checking the wires that go to the PCM . If they test good then what? New PCM?!?
Old Jun 12, 2010 | 02:32 PM
lucky131969
Possible....yes....probable....no.
Since you did have damaged wiring, I would approach in the following way:
1) If fuse #15 is good, then check for 12 volts at each O2 harness connector at pin D, brown wire(s)....ignition must be in "on" position for this test.
2) At the same connector(s), check the resistance to ground at pin C, black wire(s).
For the inactivity issue, you'll need to evaluate the sensor wiring between the PCM and O2 connector(s) at the harness. Disconnecting PCM connector C1, and reading the resistance to ground of each individual wire from the PCM connector to the appropriate O2 sensor connector. Also check for shorting by checking the resistance between the wires themselves, and finally continuity of each wire. All these tests must be done with the PCM connector, and O2 sensors disconnected.
Note, this will only evaluate the O2 harness.
Old Jun 14, 2010 | 08:33 PM
cracker Bear
OK OK... sorry its been a few days ive been out of pocket.. just started testing the harness at the o2's i got 12v on the brown but i dont have ground on the black.. ive checked my engine grounds they are all hooked up.. should i cut the black wires and just run them to ground.. would that be ok?
Old Jun 14, 2010 | 08:54 PM
lucky131969
That would not be my approach, because the wiring is already in place, so you need to investigate where the open is. You've gone to the trouble to do an engine swap, don't start rigging up stuff now. Hard to believe all the grounds are bad at the splice pack, unless some creative wiring was done in this motor swap.
Hopefully you are checking each connector v/s a known good ground. If you are confident this is the case, then SP122 is the common connection point. If the oil level and fuel pump relay are working, you at least know the ground from G105 to SP122 is good......so you'll have to figure out what the problem is.
Old Jun 14, 2010 | 09:02 PM
cracker Bear
oil level keeps saying low oil.. fuel pump relay clicks but doesnt put voltage to the pump.. had to by pass... no wires were cut or spliced during the motor swap...
Old Jun 14, 2010 | 09:10 PM
cracker Bear
i also checked the purple and tan wires for the inactivity problem they both test out fine,, not shorted or open
Old Jun 14, 2010 | 09:21 PM
lucky131969
You don't say?
That being the case, you most likely left off (or damaged) one of the ring terminals at engine ground G105(as below). One is the ground strap to the frame, and the other is a ground for SP122, which provides a ground for the fuel pump relay, oil level sensor, and O2's. Stop bypassing things that don't work, and fix the problem.
http://forums.corvetteforum.com/c5-t...e-grounds.html
Old Jun 14, 2010 | 09:48 PM
cracker Bear
You don't say?
ive tested this ground as far back as i can and it has ground.. so it must me damaged pretty far down the line.. im not about to pull my motor for somthing as simple as runnin new ground to my o2. thats insane. would the lack of ground cause the inactivity..
Old Jun 14, 2010 | 10:40 PM
lucky131969
Perhaps you are not understanding me, or cannot read the schematics....or have not read the info I have posted....so I'll leave you with this.
I'm not suggesting, in any way, that you pull the motor to resolve this issue. The reason why your fuel pump, oil level, and O2 heaters are not operating correctly is due to a ground issue..specifically..lack of ground. All the aforementioned are connected to SP122, which is located under the battery tray. SP122 is grounded at G105. Fix the ground, and fix ALL the issues.
Good luck.
Old Jun 15, 2010 | 10:01 PM
cracker Bear
Good luck.
im sorry if i sounded ungreatful, im just paniced... 12k$ and im having probs... i found that i have 3 grounds at this connection one that had been tucked into a set of wires and so far so good except my afr under a load is 11.5
To O2 codes need serious help
