Strange AC Issue
Old Jun 12, 2010 | 02:06 PM
Skymac's Avatar
Skymac
Default Strange AC Issue
Anyone got any ideas on why I only get cool air out of the two passenger vents and passenger side defrost vent? Just ambient temp air comes out of the driver side and center vent when the A/C is on.
If you turn the heat on then heat comes out of all vents like normal, but when A/C is on only out of the left side vents... Im stumped but im sure its something simple. Flow also changes when I select bottom vents, etc like normal.
Old Jun 12, 2010 | 04:02 PM
Rohan's Avatar
Rohan
Thanks[/QUOTE]
I have the same exact problem. Hopefully someone will help us out here.
Old Jun 12, 2010 | 05:08 PM
chris308's Avatar
chris308
same issue here, and i'm about 98.76% sure it's a vacuum line issue, just haven't looked at mine yet.
Old Jun 12, 2010 | 06:58 PM
byronhunter's Avatar
byronhunter
You've got 2 choices, Actuator problem, (check for codes), or low on Refrigerant. Do a search for this problem, must have been discused 100 times before.
Old Jun 12, 2010 | 07:15 PM
Skymac's Avatar
Skymac
Well it's ice cold on the right so doubt it's low.. I'll check for codes
Old Jun 12, 2010 | 08:18 PM
SebringSixSpeed's Avatar
SebringSixSpeed
I know its very strange to have the cold air on the pass side and be low on refridgerant but let me assure you that it's completely possible and inherent to the design of the vettes a/c system. I have personally been through this issue so let me try to explain how it happens. The low level of freon can still have just enough energy as it enters the evaporator to create a cooling effect on the first half of the evaporator but it's energy is not strong enough to cool the entire thing. So think of half of the evaporator getting cold and the other half basically not being affected because the refridgerant has lost all it's energy due to the low level. Now consider that the passenger side vents are taking air from the first half of the evaporator and the drivers side vents are getting the ambient temp air from the second half of the evaporator that has not become chilled.
I wrestled with this idea for awhile until I hooked up my gauges and added freon until I got about 290 psi on the high side and whadda ya know, ice cold air on the drivers side to go along with the cold air on the passenger side - believe it.
Old Jun 12, 2010 | 09:01 PM
byronhunter
SebringSixSpeed has got it Exactly right!!!!!!!!!! It does also happen to other GM cars, ask Me how I know.
Old Jun 12, 2010 | 09:59 PM
rebelheart's Avatar
rebelheart
This is pretty common,you most likely are a bit low on freon.
Old Jun 13, 2010 | 12:25 AM
Skymac's Avatar
Skymac
290 at idle?
It's at 195 at idle now...
Old Jun 13, 2010 | 08:56 AM
SebringSixSpeed
No, 290 psig at approximately 2000 rpm (servicing a/c at idle can be frustrating). but that was for my ambient temp and humidity. Hot and humid. For reference, if you have a 90 degree F day and 80% humidity, at idle you should have about 225 psig on the high side. If you rev it up to around 2000 rpm the pressure will go up. If you don't think its the freon level go ahead and put a new actuator in like I did, then when you still have the same problem add the freon. Those are the only two causes of the simultanious warm/cold condition.
Old Jun 13, 2010 | 09:06 PM
C5 Corvette C5's Avatar
C5 Corvette C5
Yea I have the same problem. Got any ideas yet of what it is?
Old Jun 13, 2010 | 09:21 PM
SebringSixSpeed
Old Jun 14, 2010 | 09:17 AM
Rohan's Avatar
Rohan
Low freon was my problem. Would have never thought to check that first. THANKS GUYS!!!
Old Jun 14, 2010 | 11:41 AM
rebelheart's Avatar
rebelheart
Beats tearing down the dash doesnt it?!
Old Jun 14, 2010 | 01:02 PM
Skymac's Avatar
Skymac
Well I haven't taken down the system yet, will probably do that soon though.. I mean if its low, then its low for a reason of course so I want to find the reason instead of just masking the problem. This is all great information and thanks for the help.
Old Aug 2, 2010 | 09:07 PM
883stump's Avatar
883stump
I am having the same prob.... I am told its low on refridgerent also, even though I had it checked and I was told its was fine, I have to believe its low on freon, cause i am told this system is finiky and can be to high one way and to low the other and it can cause this problem..... I will try to add some freon and see what happens......
Old Aug 9, 2010 | 05:57 PM
Pie R Squared's Avatar
Pie R Squared
Check to see if you have green oil (it's PAG with dye) leaking from under your car, if so then the AC compressor is going bad.
To Strange AC Issue
