seized ball joint bolt
Old Jun 12, 2010 | 11:00 PM
HowlinC5's Avatar
HowlinC5
Default seized ball joint bolt
Anyone ever had a lower ball joint stud seize to the bolt? If so whats the best way to free it up? I tried pb blaster. Thanks in advance.
Old Jun 13, 2010 | 01:49 AM
lionelhutz's Avatar
lionelhutz
You mean the nut is stuck on the stud? does it just turn? How does the stud have a bolt?
Peter
Old Jun 13, 2010 | 02:30 AM
socalman's Avatar
socalman
St. Jude Donor '10
torch? heat sometimes works
Old Jun 13, 2010 | 06:25 AM
rclinton's Avatar
rclinton
Veteran: Marine Corps
If you mean the NUT holding the ball joint on then try this. With the car already jacked up, put a bottle jack under the lower ball joint to keep pressure on it. You should be able to remove the nut .
Old Jun 13, 2010 | 05:45 PM
HowlinC5's Avatar
HowlinC5
Thanks guys, I ended up being able to retighten the bolt this morning and decided it was easier to drop the lower control arm by unbolting the upper control arm.
Old Jun 13, 2010 | 06:27 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You're suppose to use an allen wrench to hold the stud while lossening and tightening.
Old Jun 13, 2010 | 09:34 PM
HowlinC5's Avatar
HowlinC5
^I did that! It was just really rusty and I was afraid of breaking the stud.
To seized ball joint bolt
