Projector HID wiring Issue.
Old Jun 13, 2010 | 11:37 AM
Blown 346's Avatar
Blown 346
Default Projector HID wiring Issue.
I have the corvette garage Projector ACA hid kit on my 01 Z. I had the pasenger side housing break on me last year. I ordered another Projector kit from the auction site. When I got the new lights in, all I did was swap out the Projector that came with my new lights and installed my old projector with the HID in the new housings place.
Everything worked great with the exception of one thing. The headlights will not go down if the car wasnt running. When you turned the lights off while the car was off, you would hear for a split second like they wanted to go down but wouldnt...
I thought maybe the wire connectors were wrong, so I swapped them and had my brights come on. Then the Passenger HID stopped working. Now only my driverside HID turns on, The passenger side does not, unless I swap one headlight plug on the passenger side and reverse the polarity. Once I swap that one plug, both HID's and brights go on without having the brights on, and the headlights will close.
I swapped the plug back to its normal position and yet again no HID on the passenger side.
I did not replace or touch the Corvette garage main wiring harness, just simply swappped the Projecotrs out of my old housings with the new ones.
Here's how the wiring is setup.
Stock harness connecting to Corvette Garage harness.
Green/Black wire plugs into Connector with red/black/white wires.
Red/Black wires connects to Brights.
Black/tan plugs into Green and what looks like silver wire or (White Plug)
Then you have the black wire that connects to the green wire. The one that just pushes together.
It seems when I reverse the polarity, both HID's work, but the brights come on as well without me turning the brights on.
I checked the fuses on the Corvette Garage kit, and all 4 20 amp fuses are good. The ballast is still good.
Any help would be great.
Old Jun 13, 2010 | 06:34 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sounds like you have a bad bulb or ballast that is throwing off the resistance.
Old Jun 13, 2010 | 08:37 PM
Blown 346's Avatar
Blown 346
Im about to swap the bulbs out and see if that makes a difference. Ill swap ballasts and see what happens.
What I dont understand is the Bright isnt working at all either. Would the ballast effect that since that wiring harness runs the HID and the Brights as well?
Old Jun 13, 2010 | 09:27 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The high beams use the stock wiring thru the relays. That what allows you to have your low and high beams on at the same time.
Make sure your positive and negatives are properly orientated. I've seen where the red (positive) and black (negative) are sometimes reversed, especially on the China made ballast.
Old Jun 14, 2010 | 01:19 AM
Blown 346's Avatar
Blown 346
The passenger side relay took a dump. It doesnt do anything anymore.
The ballasts im running are Phillips from the Corvette Garage HID ACA Kit.
Edit.... I just changed the Relay and still the same outcome. No HID or Brights on the passenger side. I pulled the Bright from the driver light as I know it works, and moved it to the passenger. It doesnt work either.
I swapped the ballasts and the Driver HID lit up, (so the ballasts are not the issue)and the passenger side bulb did not. I took the HID bulbs out and put the driver side in the passenger and vice a versa. Both HID bulbs work, but only on the driver side.
Neither the HID or High Beam on the passenger side work, no matter what ballast or which HID I use. All 4 fuses and both Relays work.
I have an issue that started once the Passenger side HID and High beam stopped working. When I turn the parking lights on, the guage cluster lights up for about 2 or 3 seconds and then goes out. The battery is be charged by my trickle charger.
I have no clue what is going on. I would be grateful if someone with Electrical experience could help figure this mess out.
Old Jun 14, 2010 | 08:19 AM
lucky131969's Avatar
lucky131969
I'll PM you my number. If we can't get it resolved on the phone, I can run out there.
Old Jun 14, 2010 | 09:38 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
^ I'm sure Lucky will be able to resolve the problem quickly.
Sounds like some kind of harness or power problems on the passenger harness.
Old Jun 14, 2010 | 07:16 PM
Blown 346's Avatar
Blown 346
Lucky Got it figured out over the phone. It turned out to be 2 bad fuses in the fise panel under the hood after checking voltage.
Thanks again.
Old Jun 14, 2010 | 07:22 PM
lucky131969
Thanks again.
Old Jun 14, 2010 | 08:02 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks again.
I knew Lucky would figure it out. It helps to have schematics and a multi-meter as they are best friends when it comes to electrical problems.
To Projector HID wiring Issue.
