Window Felt Alignment
Old Mar 20, 2002 | 09:59 PM
Bandit1's Avatar
Bandit1
Default Window Felt Alignment
Have had the vette in for service a couple of times for passenger door interior window felt alignment with the exterior felt (interior felt does not meet the exterior felt when window is rolled down--it bows down lower). Service tech replaced the door panel and aligned which fixed the problem pretty much. After a second visit for a different problem for an insulation check in the door (panel had to be removed for repair), the interior felt is not aligned with exterior felt again--bows down lower). Can anyone help me out with this? :confused:
Old Mar 21, 2002 | 11:23 AM
marcelwinner's Avatar
marcelwinner
Default Re: Window Felt Alignment (Bandit1)
I think I have the same problem. When I wash my Vette, water always get down between the felt and windows and leaving streaks on my windows when I roll them up and down after washing. I think this may be the same problem, eh? If so, let me know if you find out any way to fix it. Also, would this be covered under warranty?
Old Mar 21, 2002 | 04:43 PM
C5 Freak's Avatar
C5 Freak
Default Re: Window Felt Alignment (marcelwinner)
I have the same mis-alignment on mine. It's good old GM quality workmanship.
To Window Felt Alignment
