AC Problems
Old Jun 13, 2010 | 09:05 PM
C5 Corvette C5's Avatar
C5 Corvette C5
Default AC Problems
Ok so I turn on my AC and its blowing cold, but only on the passengers side. The drivers side is not cold. Then I turn the fan up all the way, and I have to put my hand inches away to feel the air. Next, I tired to change the mode and it won't change. The air blows out of all directions head, feet, and defrost.
Problems
1 Blowing cold only on passenger side
2 Not blowing hard
3 Not changing blowing mode
I looked at the blower motor and its all clean.
I want to check the AC vacuum lines, but i dont know exactly where they are. Anyone have any pictures to help me out.
Anyone have any idea of whats wrong, let me hear what you think.
Thanks to all replys
Old Jun 14, 2010 | 12:19 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The Vent Modes are VACUUM controlled. Your missing the vacuum signal that comes from the back of the intake manifold.
Old Jun 14, 2010 | 10:04 AM
wclark@nj.com's Avatar
wclark@nj.com
Did you check all AC related fuses and see if any codes were set? Did you have the intake off recently for an oil pressure sending unit or clutch replacement? – If yes, then I would check the vacuum line mentioned in the previous post.
To AC Problems
