Mod Question??
We discussed Torque Converters, rearends, NOS, everything.
He told me, to do the rear end differential AND torque converter at the same time. Basically, you take out the tranny to change the rearend, so you might as well put in a converter at the same time and save a boat load of labor. Also, you then need a Hypertech, or some programmer to reprogram the ECM for the new rearend and such. I'm stuck there, because Hypertech doesn't have a programmer for the 2001, only the 2000 and older. I've TTS has poor customer service, and I just don't know enough about the LSI Edit to talk intelligently about it.
So, I do plan on either a 3.42 or 3.15 rearend and a P.I. vigilante 2600. The mechanic told me about 12 hours labor for both, including the reprogram. I think I can work that a little better though even though they are giving me a cut on the hourly rate. The mechanic has mostly done Yank rearends, but my service manager told me to do a 2600 stall and not a Yank 3000. And he is the one who is going to continue to honor my warranty with all my mods, including NOS, so I follow his advice.
You'll have to do an awful lot to get into the 11's though. Your biggest problem will be traction, and unfortunately no one make a drag radial for an 18 inch wheel. There is a big email campaign right now with Nitto to try to encourage them to make a drag radial for the 18 inch wheel. That post is here:
http://forums.corvetteforum.com/zerothread?id=257050
So, good luck on your mods.
Kurt
If you want a louder exhaust note, there are a few cat-back exhaust systems that will be nice and loud, Borla XR-1, SLP Loudmouth, PRT's should be louder too. Headers will make your car louder too.
Best advice I could give you is to find a local tuner and work with him/her.
Good luck with the labor. Eric
[Modified by ericg320, 5:00 AM 3/21/2002]
[Modified by ericg320, 2:10 AM 3/22/2002]
[Modified by ericg320, 2:11 AM 3/22/2002]
I would personally stay with the 3.15, and I think the 2600 stall is perfect for it, and so does my Corvette guy at my dealership.
Also, make sure you add air induction and a coupler. Cheap, cheap HP.
Good luck with the mods.
Kurt
There are many heads and cam C5s who have not quite broken into the 11s yet and without at least the above I think you are dreaming unless you went with a hard hitting torque converter, gears and 150 shot of N20 and et streets. Otherwise, forget about it, its not as easy as most think (without the aforementioned mods). The fastest C5s naturally aspirated without heads/cam usually see 12.1 to 12.4 (under perfect conditions). Don't forget its tougher to get a C5 into the 11s vs and f-body b/c of the solid axle of the f-body (camaro/firebird) and non IR suspension (unlike theC5) makes the weight distribution for dragging more desirable in a F-body.
My advice, first off definitely go with t. converter and at least 3.42s right off the bat b/c this will change whole complexion of your car and will shave .5 sec off ets. Also, from the get go ditch stock intake and go with ram air set up such as MTI< Vortex, Donasldson, etc. THen, save for stage II heads, cam, longtubes, Ls6 intake, PC etc and forget about the basis BS bolt ons. Then you will see 11s. A cheaper route would be to go with N20 (unless you prefer N/A like me) and that will get you screaming to especially with t. converter and gears.
Goodluck and be safe and I most warn you (mod attack is extemely addicting and your car will never be as reliable vs. keeping it stock. You will pay to play and i speak from experiece as i toasted my A4 tranny just 700 miles after t. converter and gears and one hour after getting car back with heads/cam :U Don't mean to bum you out, but feel you need a realistic warning concerning the fact that "YOu defintely have to pay to play! I miss the reliable confidence that my car had b/f becomming an 11 sec machine but would never go back if i had it all over to do again b/c I am a HORSEPOWER FREAK, like most others here! LOL
Nitrovette :smash:
[Modified by Nitrovette, 10:55 PM 3/21/2002]
[Modified by Nitrovette, 10:56 PM 3/21/2002]
[Modified by Nitrovette, 10:58 PM 3/21/2002]
[Modified by Nitrovette, 11:00 PM 3/21/2002]
[Modified by Nitrovette, 11:14 PM 3/21/2002]
Take a look at my sig. I run consistent high 11's. I should be running faster, but there is a problem with the 2001 auto's and torque. I don't get full throttle until after 5200 rpm's. The computer genius' are working on that now. The 2000's do not have this problem. I would definitely go with the 3.42's., and if you can get away with it, a 3000 or higher stall converter.
I'm sure you can get 11's with bolt ons without heads/cam, but I believe you'll need nitrous.
