Wire Routing for left front speed sensor
Thanks in advance!
Bill
Connector Part Information
• 12052644
• 2 Way F Metri-Pack 150 Sealed (LT GRY)
Pin Wire Color Circuit No. Function
A WHT 873 Left Front Wheel Speed Sensor Low Reference
B BLK 830 Left Front Wheel Speed Sensor Signal
Electronic Brake Control Module (EBCM)
• C1 - 15401425
• 7-Way F Metri-Pack 480, GT 150 Mixed Series (BLK)
• C2 - 15356700
• 29 Way F Micro-Pack 100 Series (GRY)
A RED 1642 Battery Positive Voltage
B BRN 641 Ignition 3 voltage
C GRY 1787 Variable Effort Steering Actuator High Effort Control
D WHT 345 Variable Effort Steering Actuator Low Effort Control
E -- -- Not Used
F BLK/WHT 1251 Ground
G BLK 1250 Ground
1 -- -- Not Used
2 TAN/BLK 464 Delivered Torque Signal
3 LT GRN 1763 Steering Wheel Position Signal A
4 -- -- Not Used
5 LT GRN/BLK 1338 Lateral Accelerometer Input (JL4)
6 LT BLU 20 Stop lamp Supply Voltage
7 -- -- Not Used
8 RED 885 Left Rear Wheel Speed Sensor Low Reference
9 BRN 882 Right Rear Wheel Speed Sensor Signal
10 DK GRN 872 Right Front Wheel Speed Sensor Signal
11 LT BLU 830 Left Front Wheel Speed Sensor Signa
12 ORN/BLK 463 Requested Torque Signal
13 ORN/BLK 556 Low Reference
14-16 -- -- Not Used
17 BLK 2626 Brake Pressure Sensor Signal (JL4)
18 LT BLU 1764 Steering Wheel Position Signal B
19 DK BLU 71 Yaw Rate Sensor Signal (JL4)
20 -- -- Not Used
21 LT BLU 1122 ABS/TCS Class 2 Serial Data
22 BLK 884 Left Rear Wheel Speed Sensor Signal
23 WHT 883 Right Rear Wheel Speed Sensor Low Reference
24 TAN 833 Right Front Wheel Speed Sensor Low Reference
25 YEL 873 Left Front Wheel Speed Sensor Low Reference
26 -- -- Not Used
27 GRY 1056 Steering Wheel Position Sensor 5V Reference Voltage
28 LT BLU 2627 Steering Position Sensor Signal
29 -- -- Not Used
