Engine trouble. Take a guess for me
Old Jun 16, 2010 | 11:34 PM
SteveNewcomb's Avatar
SteveNewcomb
Default Engine trouble. Take a guess for me
I have a 98 ls1 with a cam headers high flow cats and corsa exhaust I bought the car already done I've had it a year and it has run great no issues until tonight. I was driving and got on it pretty hard now it's running terrible it almost dies out while stopped and I got out and looked under it and the drivers side cat is glowing hot. All the gauges seem to be normal. I shut it off and had a hard time getting it started to pull it in the garage. Anybody want to chime in as to what it could be. I am thinking it may be the timing but I do not know much about that. Can punching it at 20 mph cause the timing to jump? Any help would be appreciated.
Old Jun 16, 2010 | 11:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
PULL YOUR DTCs and post them!!!!!
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Jun 16, 2010 | 11:47 PM
SteveNewcomb
I'm not sure if driving it like it is will damage anything.
Old Jun 17, 2010 | 01:17 AM
Jeffwilson34's Avatar
Jeffwilson34
something tells me that you may have a O2 Sensor wire burned, ask me how I know.
Check and see if your tailpipe is extra black?
Jack it up and check the wires on the sensors going towards the engine compartment.
They have a habbit of rubbing up against headers
or.
Do you still have cats? One may be bad also.
Old Jun 17, 2010 | 03:48 AM
Blown 346's Avatar
Blown 346
Normally when a Cat is glowing red it is bad and needs to be replaced. A bad cat will cause the car to run horrible.
Old Jun 17, 2010 | 11:07 AM
dankhts's Avatar
dankhts
had it happen to me - car would hardly go.... but pull the codes and let's see them!
Old Jun 17, 2010 | 12:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You dont have to drive the car to pull the DTCs. The codes are set from the past problem. Somehow your getting a lot of unburned fuel in that bank exhaust. Could be a broken spring, bad injector, O2 sensor...etc
The DTCs normaly help us narrow down the issue. Sometimes a problem can cause weird or NO DTCs but, thats rare. Im leaning towards a broken valve spring.
Bill
Old Jun 17, 2010 | 02:01 PM
Chicago1's Avatar
Chicago1
Pull the codes!!!!
Old Jun 17, 2010 | 02:23 PM
dougbfresh's Avatar
dougbfresh
Too much unburnt fuel in the exhaust on 1 side or cat is plugged-bet 1 or more exhaust valves have some sort of "issue" on that side.
Old Jun 18, 2010 | 09:07 PM
SteveNewcomb
Codes
Ao LDCM R2282 H
** * * * * * *B2284 H
** * * * * * *U1064 H
A1- RDCM
** * * * * * B2283 H
** * * * * * B2285 H
** * * * * * U1064 H
BO-RFA
** * * * * * *U1255 H
** * * * * * *U1096 H
** * * * * * *C2120 H C
Old Jun 18, 2010 | 09:29 PM
SteveNewcomb
or.
Would that explain a burning plastic smell I could not find before this happened? I'll have to check. Started it up today and it fired right up but ran terrible. I shut it off and it wouldn't start right back up and I can smell a little gas. Would a burnt 02 sensor cause that?
Old Jun 18, 2010 | 09:53 PM
redrckt97's Avatar
redrckt97
I'd bet on a broken valve spring - common issue ... will put a lot of unburnt gas out through the cat and Really heat it up. You should not be running it - hopefully with the cam the previous owner put in dual springs so you don't have so much risk of dropping a valve.
Old Jun 18, 2010 | 10:39 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
To Engine trouble. Take a guess for me
