Can't shift to reverse. Please Help...
Old Jun 17, 2010 | 04:36 AM
gofastcar's Avatar
gofastcar
Default Can't shift to reverse. Please Help...
Hi Guys,
I've been having this problem for a week. I can't shift to reverse in the morning ( while the car is cold). I need to wait for like 15 min, until the car is fully warm to be able to shift to the gear. I've changed the differential oil, but it doesn't quite help. The problem now seems getting worse, since other gears are starting to get the same symptom.
Anyone can give me some advice of what I should do? Thanks so much in advance!
Patrick
Old Jun 18, 2010 | 12:48 AM
gofastcar's Avatar
gofastcar
any clutch pros?
Old Jun 18, 2010 | 01:19 AM
-DLS-'s Avatar
-DLS-
Will the shifter just not go all the way to the right?
Thats weird, but I would go into the DIC and see if your reverse lockout solenoid is acting up.
It won't throw a light on the dash but it will throw a code.
Old Jun 18, 2010 | 03:29 AM
gofastcar's Avatar
gofastcar
Thanks!
the shifter will go all the way to the right, but just not to the reverse.
and it works for the rest of the day, at least while the car is warm. I will check out the reverse lockout tomorrow.Thanks
Old Jun 18, 2010 | 03:44 AM
-DLS-'s Avatar
-DLS-
Definitely sounds like it's the lockout solenoid then. I can't see it being anything else if the trans actually shifts the rails.
Also, diff fluid is diff fluid. It has nothing to do with your trans.
Your trans has its own fluid and its sealed away from the diff. To check the level its the golden bolt / electrical connector on the driver side. Take it out and make sure that there is enough fluid level with the bottom of the hole.
Our tran's take dexron III ATF not MTF. I used amsoil.
Old Jun 18, 2010 | 09:24 AM
Jims79's Avatar
Jims79
did you try to realign the shifter? I had trouble popping out of rev when cold. I had to hold the shifter in rev while backing out of my driveway. Then I realigned the shifter & chg'ed my tranny fluid and no more popping out or grin going into rev. G/L
Old Jun 18, 2010 | 10:40 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
It depends on the year of your car as to whether or not it could be the lockout solenoid. On '97-'00 the solenoid is engaged with power off. If the solenoid goes bad it will prevent you from engaging reverse. On '01-'04 cars the solenoid is engaged with power on. If it goes bad it will not lock out reverse, even with the car moving forward.
You problem sounds more like a synchro issue than a solenoid.
Old Jun 18, 2010 | 01:36 PM
-DLS-'s Avatar
-DLS-
I'm thinking then it would grind instead of block it out.
Old Jun 19, 2010 | 09:38 AM
C5ZEE06's Avatar
C5ZEE06
did you bleed the clutch hydraulics ?
a Tick master install solved my identical problem.
Old Jun 19, 2010 | 10:39 AM
lionelhutz's Avatar
lionelhutz
It sounds like the shifter may have slipped on the torque tube. When it's in neutral with it centered (ie 3/4 gear slot) does the shifter still seem to be straight up and down? If it seems off or has more shifting slop then pull the console and check the alignment and general condition of the shifter.
Peter
Old Aug 13, 2010 | 01:45 PM
MotleyDrew's Avatar
MotleyDrew
Mine just started doing the same thing....reverse is hard to find but when it goes in its good. Like you said after the car is wam it seems easier to get it in. Let me know what you find ! I have a fully built MN6
take care
Old Aug 13, 2010 | 03:14 PM
Bloodvette's Avatar
Bloodvette
mine does not want to go all the way into reverse. It feels like it only goes half way in.
if I let the clutch out slowly and keep pressure on the shifter, I hear/feel a light clunk and then its in. otherwise, if I try to drive with it half way in, it sits there and grinds until I pull it back out.
Could this be shifter alignment?? (sorry for the highjack)
Whats the procedure for checking your shifter alignment? anyone know off hand?
john
Old Aug 14, 2010 | 02:41 PM
Paul 75 L82's Avatar
Paul 75 L82
You have to remove the bolt that goes thru the shifter collar and tightens the transmission rod. The notch in the transmission rod needs to be in the center of the bolt hole. If it's not in the center you have to loosen the shifter bolts and move it forward or to the rear.
Old Aug 14, 2010 | 03:39 PM
netster's Avatar
netster
Not sure if this will help, but you can always do the "put it into first, then put it in reverse trick".
Old Aug 14, 2010 | 05:24 PM
Carcass's Avatar
Carcass
If the pilot bearing is dry,or grenaded,it will grab the propshaft and keep it spinning even when the clutch is fully disengaged( it's also chewing up the end of the propshaft while it's doing this) so first or reverse will be difficult if not impossible to get in to.
Just a thought-those were my symptoms when I destroyed a pilot bearing during a clutch install,and got to do the whole thing over again.
I went with a Kevlar/Composite pilot BUSHING on the second go-round,and it's all been good for the last 6k miles...
The pilot bearing is the last piece to come out once you drop the drivetrain and remove the clutch,so I really hope that's not what's causing your issue.
Old Aug 14, 2010 | 10:46 PM
MotleyDrew's Avatar
MotleyDrew
i Just installed a new "solid metal bushing" in mine when I did the last clutch job about 2500 miles ago....It is dry by nature but the last one ran 12 miles without issue so I used the same type instead of the typical bearing. Where did you prurchase your bushing and can you provide the part#? thx
Old Aug 15, 2010 | 01:54 AM
Carcass's Avatar
Carcass
http://forums.corvetteforum.com/c5-t...rivetrain.html
It's a little tiny thing,doesn't look like it's worth the money,(what Vette stuff does?)but 6k later,it's working great,and no worries about f**king it up reinstalling the drivetrain,it's very forgiving,unlike the stock needle bearing arrangement.
DO NOT grease it-that will just make dirt stick to it.
BRONZE is probably ok,too,and they're like 3 bucks,but we're talkin about my Vette here....
Can't find the part # at JEGS,but this should point you in the right direction:
http://blogs.carcraft.com/6608014/ed...ngs/index.html
To Can't shift to reverse. Please Help...
Old Aug 15, 2010 | 10:13 AM
MotleyDrew's Avatar
MotleyDrew
thx bud
Old Aug 16, 2010 | 03:17 PM
gofastcar's Avatar
gofastcar
Thanks so much for the help guys. I finally fixed the car. It was the clutch master cylinder. It got stuck and unable to return to normal position. It has exactly the same symptom as broken return spring, but turns out the spring is fine, but the master cylinder. Hope it helps.
Old Aug 16, 2010 | 03:28 PM
MotleyDrew's Avatar
MotleyDrew
Great work bud ! thanks for the update
