Preventative Medicine
Old Jun 19, 2010 | 01:00 PM
pgj98m3's Avatar
pgj98m3
Default Preventative Medicine
I have the C6 sway bar upgrade sitting in my garage and would like to put them on my C5 FRC today. I have limited mechanical skills but I do learn...slowly.
It looks like a straightforward procedure but if there are any hints or warnings I would truly appreciate them....
Old Jun 19, 2010 | 01:19 PM
Bret01Z06's Avatar
Bret01Z06
If you have a FRC you most likely have plastic end links. I hope you ordered the upgraded metal ones with it. If not order those then change the sway bar. I tore up my plastic ones getting them off.
Old Jun 19, 2010 | 07:51 PM
pgj98m3's Avatar
pgj98m3
Thanks I got the GMparts package which included the metal end links
Old Jun 19, 2010 | 10:12 PM
imavettegirl's Avatar
imavettegirl
make sure you put the rear bar in the rear and the front bar in the front.
sorry, i could not resist after reading your other post and your front/rear bar mixup. ;-)
To Preventative Medicine
