Make sure you have FREON, , , , , , , , , , , , ,Or hit the AC button again, sometimes mine has to be pushed more then once to stay on or off. Something to do with the automatic units.................Ya know computer controlled.......
Check your freon pressures. If they're good, check fuses and small grey relay in the under hood panel. My A/C stopped working until I replaced the A/C relay with my horn relay.
i just had my ac charged and they could not get it to blow cold throught the headunit. they could jump it throught the engine compartment fuse box tho? I just checked and i have no codes either.
