Shifter rattling
Old Jun 20, 2010 | 11:28 AM
CaptWSims's Avatar
CaptWSims
Default Shifter rattling
This weekend my shifter in my 2001 Z06 suddenly began rattling. What is the fix? Had this in another car and fix was to install a thin nylon sheet to isloate the shifter's pivot ball from the socket.
I gather from reading other posts that the early Z06 has a solid shifter that's prone to this rattling. For the record, the car shifts beautifully and has 46K miles logged.
Old Jun 20, 2010 | 11:36 AM
imavettegirl's Avatar
imavettegirl
tad more info needed.
stock or aftermarket?
ever had it apart?
the bushing at bottom of shifter may be worn.
Old Jun 20, 2010 | 11:47 AM
CaptWSims's Avatar
CaptWSims
Default Rattling shifter
Is stock, never has been apart, to my knowledge. Did replace an aftermarket shift **** about 10 days ago with another aftermarket **** that is a bit heavier. Rattling did not start right away, but about 5 days later.
Old Jun 20, 2010 | 11:50 AM
CaptWSims's Avatar
CaptWSims
Default Shifter
I understand the early Z06 had a different design that doesn't use the rubber bushings that fail so often on other Vettes. Haven't pulled the shifter yet for inspection.
Old Jun 20, 2010 | 11:56 AM
CaptWSims's Avatar
CaptWSims
Is the OEM shifter for C5 Z06, I believe (bought car used). The **** is on tight.
Sounds like I need to tear into it and see if I can find anything loose or worn.
Old Jun 20, 2010 | 05:25 PM
imavettegirl
if it happened after **** was on then it has to be something with the ****.
Old Jun 20, 2010 | 05:48 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
All C5's with manual transmissions have the same shifter. What is different in the Z06 is the mounting box. It has solid bushings where the non Z06's had rubber bushings.
A heavier **** would certainly be prone to more vibration. Go back to the other **** and see if it goes away.
Old Jun 20, 2010 | 09:48 PM
CaptWSims's Avatar
CaptWSims
I'll try that. Didn't start right away...was about 5 days after heavier **** was installed.
Old Jun 21, 2010 | 08:33 PM
CaptWSims's Avatar
CaptWSims
Tried the old **** (which is broken, thus being replaced) and the rattling went away. Weighed both ***** and was surprised to find the old **** weighs 170 grams, the new **** just 100 grams. Increased the weight of the new **** by filling it with a sawed off bolt and JB Weld and using a heavier lock bolt. That fixed the rattling!
To Shifter rattling
