NEED HELP car overheating
thanks
Many have the turn on temps reprogrammed to lower temps.By the way the fans are commanded off at 35mph and above by the PCM. Free wheeling fans apparently block less air flow through the radiator than do spinning fans at 35mph and above.
thats normal ? seems kinda odd to me but heres the details bout it first i couldnt drive the car with the ac on cus of the temps but then i changed the t-stat and i am able to run the ac while driving on hwy roads the car is about 196-198deg but when i get in town and drive from light to light car will rise up temps and ive seen them go to 230 but once i get moving car will cool down so i changed the fans and now the car will run fine with the ac off and when i was driving around the neighborhood and thats when the temps went up to 225 with the ac on so im not sure what else to do
C5 Cooling Fans Operation
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
When you have "cooling problems" always check the radiator for foreign material (grass, leaves, plastic bags, etc.), since these C5s are bottom breathers, they act as road vacuum cleaners.
ok based on 100% experience with the C5 nothing else, 225 is at the uppor limits of normal. (ive read the book) I had the same exact issues car would get to 225 maybe even a little warmer at times. Whats the weather like? well your in for worth its probably hot as hell right now. Also did you pay close attention to your temps before this did your car always reach 225 and stay there? if not, then its not normal. anyway to get to my point and help ya out, if I were a betting man id put my money down and say even though you cant see it in its current location, if you were to pull the radiator out (which isnt that hard) I'd be willing to just about gurantee that you either can not see through the fins of your radiator or its very hard to see.
HOW TO FIX?
Pull radiator and with a garden hose and shower type water pattern hold the hose close to the radiator and wash the fins untill you quit seeing crap come out of them and or you can see through the radiator pretty good when help up to the light. these cars are like giant street vaccuums they suck up everything. I had all sorts of crap come out of mine and you couldnt tell by looking at the radiator while it was in the car. DONT SPRAY THE THING SO DAMN HARD THAT YOU BEND ALL THE FINS ECT.
Again, no guesses here it worked for me and chances are it will probably work for you. my car reaches 220 at idle in the hot central valley california heat. maybe 222 thats pushing it. of course I gotta ask, is your water pump, thermostat, overflow tank cap and all other cooling components are in good working order?
HOW TO FIX?
HOW TO FIX?
