Are these problems related?
Old Jun 22, 2010 | 11:08 PM
C5jarhead's Avatar
C5jarhead
Default Are these problems related?
Been having a problem with the Multi Function Switch which I think Lucky hit the nail on the head but I haven’t had time to replace yet.
http://forums.corvetteforum.com/c5-t...ereabouts.html
Also been getting a check engine light about every other time I drive it but it clears up on its own.
Now, I went to start the car after it sat for about 7-10 days and it’s completely dead. I trickle charged the battery over night, she fired right up, and I went for a quick 5 mile cruise and all seemed OK. Two and a half days went by and I then went to start it this morning and it’s completely dead again, barely a click.
I checked the codes and they are all History codes but maybe they are a clue to the folks on here, so I listed them below. Normally, I suspect the battery but it has only 1 season on it and gave no signs of getting weak. I now assume alternator. Analog gauge was reading ~13 amps during the five mile cruise – that may be a bit low.
Car is hooked up to the charger again now. It’s a 2000 with 31K.
Anything I am missing before I pursue the alternator?
AO – LDCM
B2282 H Battery #1 Fault
B2284 H Battery #2 Fault
U1064 H Loss of Communications with BCM
U1096 H Loss of Communications with IPC
A1 – RDCM
B2283 H Battery #1 Fault
B2285 H Battery #2 Fault
B0 – RFA
U1255 H Serial Data Line Malfunction
U1016 H Loss of Communication with PCM
U1064 H Loss of Communication with BCM
U1096 H Loss of Communication with IPC
Old Jun 23, 2010 | 12:16 AM
lucky131969's Avatar
lucky131969
AO – LDCM
A1 – RDCM
B0 – RFA
Ok, couple of things going on here. All that loss of communication, coupled with the U1255 says you have a class 2 issue. Most common cause is the wiring in the left door.
Start with post #642 (pictures and troubleshooting courtesy of the master)
http://forums.corvetteforum.com/c5-t...n-long-33.html
If this does not resolve your issue, it's going to be time to troubleshoot the class 2 serial bus....which we can help you with.
As always, makes sure you have a good battery, and the connections are free of corrosion, and tight. May also be worth looking at the ignition switch.....but one thing at a time.
Old Jun 23, 2010 | 01:10 PM
C5jarhead's Avatar
C5jarhead
Thanks Lucky - I'll check that when I get home, and let you know what I find.
By the way - That is one amazing post that you linked me to. I didn't know the posts were numbered at first and I read on and on for a few pages. I'm glad I did - great stuff
Old Jun 23, 2010 | 01:22 PM
lucky131969
You can thank Bill Curlee for taking the time to create the thread, and share his knowledge and expertise, which has most certainly been invaluable on this forum.
Old Jun 23, 2010 | 10:27 PM
C5jarhead's Avatar
C5jarhead
Lucky,
Car started right up. Took it for another cruise and watched the Battery voltage on the DIC. It never went below 13.6 even with headlights, AC and radio for about 5 Miles.
I just finished looking at the door wiring. Here is what I found; Which looks exactly like Bills picture.
I didn't have any of that liquid electrical tape, so I taped the wire the best I could with small strips of tape and tweezers, then taped around the connector to hold it together a little better. I'll have to track down some liquid tape.
Car started right up again.
Then I ran the codes again and got two new ones;
10 PCM
P0113 C
P1111 H C
Is that because I had the wires apart and it hasn't cleared yet?
I'll see if it starts in the AM.
Thanks!
Old Jun 23, 2010 | 10:40 PM
lucky131969
Lucky,
10 PCM
P0113 C
P1111 H C
No sir, unrelated. Those codes are for the Intake Air Temp Sensor. Have you distubed the air intake, or done any work in that area? If so, inspect the wiring and connector.
Old Jun 23, 2010 | 10:50 PM
C5jarhead's Avatar
C5jarhead
No, I haven't touched anything up there and car is completely stock.
Everything appears to be in order from what I can see....?
Old Jun 25, 2010 | 11:24 PM
C5jarhead's Avatar
C5jarhead
Well it looks like the problem might be solved.
The battery is holding a charge now.
The new codes, that I mentioned, have changed to history.
I found the liquid electrical tape on McMaster Carr to complete the job properly.
Lucky and Bill – I can’t thank you enough for your help. The amount of knowledge offered on the Forum is unreal.
I plan on donating to the St. Jude’s fund every time someone saves me time and money troubleshooting/fixing a problem.I love this Forum
However, I still have the check engine light with no new codes??
Old Jun 26, 2010 | 06:16 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Once again, what a wealth of real world knowledge we have here
To Are these problems related?
