Code P0443
Old Jun 23, 2010 | 08:49 PM
Bigfoot99's Avatar
Bigfoot99
Default Code P0443
EVAP Canister Control Valve Solenoid...or something like that.
I've already changed the part but I'm still getting the code.
Saw a few threads that discussed this, but none with a solution.
Anyone have any ideas without having to hook up a scanner...which I don't have?
I have the service manuals and most of the trouble shooting goes through the scanner or shooting wires.
Any thoughts or advice would be helpful. Thanks
Old Jun 24, 2010 | 01:00 PM
Bigfoot99's Avatar
Bigfoot99
Anyone???
Old Mar 25, 2011 | 03:28 AM
c5sean85's Avatar
c5sean85
Originally Posted by Bigfoot99
Anyone???
im having the same issue i replaced the part and the code is still comming up when i plug in my diablo after i clear it.... maybe this is it, when i push on and move the bulk of wires going to the unit that has all the fuel injector wires in too the thing starts clicking back and forth.. sound like a exposed wire in the bunch??
Old Mar 27, 2011 | 11:00 AM
Bigfoot99's Avatar
Bigfoot99
I replaced the same part and still kept coming back. I got no help from here so I continued trying to figure it out.
I replaced the plastic tubing that goes from the front of the part to the intake manifold with a piece of hose to make sure it had a good seal. No problems since.
Old Mar 27, 2011 | 11:55 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Glad you got it fixed !
Thanks for reporting your solution back here. Sounds like its not a common issue (Not many replies to your prob)... but I'm sure someone will need advice on this solution one day !
Toque
Old Jun 5, 2012 | 03:54 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
0443 just came up on my personal Z06; looks to be the same issue; I replaced the entire drivetrain and I get the 443..............ahhhh the LS Corvette's are so tough(sarcasm)
To Code P0443
