car shut off well driving
Old Jun 25, 2010 | 07:48 AM
jeffreyi's Avatar
jeffreyi
Cruising
Default car shut off well driving
i have a 1999 driving down the road and the car just shut off. tried to start it and fires then shuts right down, it did this several times. also the low oil level light comes on but its right where it should be on the stick. the next day the car started right up and ran fine but today it did the same thing agian. any ideas
Old Jun 25, 2010 | 07:59 AM
65GGvert's Avatar
65GGvert
Through all this, did you even look at the codes?
Old Jun 25, 2010 | 09:05 AM
dougbfresh's Avatar
dougbfresh
Don't drive in WELLS!
Old Jun 25, 2010 | 10:11 AM
jeffreyi's Avatar
jeffreyi
Cruising
there is only 2 active codes. P0113 intake air temp sensor circuit high voltage, and P1111 intake air temp sensor intermittent high voltage.
Old Jun 25, 2010 | 10:16 AM
dougbfresh's Avatar
dougbfresh
Been fooling around with your intake?
Old Jun 25, 2010 | 10:29 AM
jeffreyi's Avatar
jeffreyi
Cruising
NO, i let the car sit for a couple hours and it started right up. this is driving me nuts
Old Jun 25, 2010 | 10:32 AM
dougbfresh's Avatar
dougbfresh
The sensor on the intake is funky, did you check it and the connector???
Old Jun 25, 2010 | 10:34 AM
jeffreyi's Avatar
jeffreyi
Cruising
yes, it looks good but i dont know how to test it.
Old Jun 25, 2010 | 12:56 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
When the car shuts down, any other IP Cluster indications at the same time? I'm initially thinking the ignition switch as a possible cause.
Old Jun 25, 2010 | 01:49 PM
jeffreyi's Avatar
jeffreyi
Cruising
nothing else came up, but that sounds about right. sometimes i have to turn the key on and off a couple time to get the radio to come on and the key fobs wont hold a program for more than a few min.
Old Jun 25, 2010 | 06:02 PM
dgrant3830's Avatar
dgrant3830
Yeah, sounds like a problem with the switch for sure. The fobs are a different issue. About the fobs, they appear to have a lifetime. Some have been able to resolder the contacts of a small black 4-pin device inside and it came to life again. Others have simply replaced the battery. Still more have had zero luck and nothing worked. Those of us ended up buying new ones and usually from Gene Culley.
Old Jun 25, 2010 | 09:39 PM
sloride's Avatar
sloride
Default My C5 is doing same thing!
My car was doing the same thing. Except my display said service steering column lock. The car was at Speed Shop so it was pulled into dyno turned off steering column lock in my computer. I have a replacement module on way. I am driving around with service steering column lock. If you need more info I can give you their email.
Old Jun 25, 2010 | 10:10 PM
sloride's Avatar
sloride
Default Read Steering Column Lock Recall thread
The Steering Column Lock Recall thread is at beginning of this Forum. You can get various syptoms. Such as car turning off at over 2 mph or message to pull key etc. The fob mesage . I have those three. It is a good thread. You need to get car to shop quick before it stops workingor leaves you stranded. I was lucky my went while at shop going to dyno. So it was pulled in temporaily fixed till part comes in.
Old Jun 25, 2010 | 11:19 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
check to make sure your battery cables are tight. I had the same thing happing many C5's ago and that is what it ended up being.
Old Jun 26, 2010 | 05:51 AM
03BlkZ's Avatar
03BlkZ
Your Air Conditioning compressor isnt locking up is it. Mine would just shut off for no reason when mine was going out. I guess too much drag at idle.
Old Jun 26, 2010 | 10:25 AM
jeffreyi's Avatar
jeffreyi
Cruising
pulled ignition and cleaned contacts, they were very dirty. but problem is still there.
Old Jun 26, 2010 | 10:56 AM
lucky131969's Avatar
lucky131969
The low oil level message, in conjunction with the engine shutting off, concerns me. The oil level sensor and the fuel pump relay both receive a ground from SP122 under the battery tray. In all fairness, the O2(s) heater circuit is grounded there as well.....so I would expect codes for the O2s if it were bad. SP122 is in turn, grounded at G105. If nothing else seems obvious, you might consider inspecting G105, SP122, and taking resistance measurements.
http://forums.corvetteforum.com/c5-t...e-grounds.html
SP122 basically looks like the pic below, but under the battery tray.
To car shut off well driving
Old Jun 27, 2010 | 11:22 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This is what it looks like when it gets battery acid vapors in it:
It actually cleaned up pretty good.
BC
Old Jun 27, 2010 | 08:17 PM
SlvrMN6's Avatar
SlvrMN6
My 98 recently started having the same issue. Same codes. Hope this helps.
Old Jun 27, 2010 | 09:22 PM
4DRUSH's Avatar
4DRUSH
BC
At that point, why not just delete the connectors and make your splice?
