interior fan, 02 vert
Blower motor control processor- pin B, 12 volts, red wire, hot at all times.
Blower motor control processor- pin A, resistance to ground, black wire
At the blower motor connector - pin B, resistance to ground, black wire
At the blower motor connector - pin A, ~4-12 volts, purple wire
With everything connected, you should also be able to backprobe pin C of the control processor(with reference to ground), and see a small change in voltage when the fan speed is changed on the control head.
