Leaking dexcool but where ??
Old Jun 28, 2010 | 09:00 AM
Z06Frank's Avatar
Z06Frank
Default Leaking dexcool but where ??
I have a strange problem…last weekend I had a puddle about the size of a coaster of antifreeze on the garage floor like almost beneath the motor. So I looked around figured well it must be my water pump gaskets so I went out bought a pair and installed them. So Friday I took out the car for a good spin parked it overnight checked no fluid leaked. Then took it out Saturday for another good spin and again parked it overnight and checked in the morning and again I had a small puddle of antifreeze on the floor. So I was like geez that’s weird! So I took it for a drive on Sunday and checked on the floor this morning and it’s dry nothing leaked….I don’t know what is going on. I am under the assumption that if antifreeze leaks it would leak all the time…Any info would be appreciated. There’s only 30,000 miles on the car so I don’t think the pump is bad.
Old Jun 28, 2010 | 09:11 AM
dougbfresh's Avatar
dougbfresh
Leaky waterpump bearing (especially in the beginning) will be sporatic. The hole is at the bottom of the pump-I'd look there 1st!
Old Jun 28, 2010 | 10:12 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The water pump coolant to waterpump vent seals are actually metal sealing rings. There made of STELITE which is super hard and the surface (when new) is like a mirror. The metal rings when mated are water tight.
The rubber seals in the pump are just there to protect the bearings from exterior water and dirt. If those metal sealing surfaces are starting to fail, it will be sporatic at first and them more constant. Clean the area well and look at the very bottom of the water pump drive pulley for sings of coolant when you see coolant on the deck.
Bill
Old Jun 28, 2010 | 11:48 AM
elderberry's Avatar
elderberry
why not use a pressure checker ?
Old Jun 28, 2010 | 12:12 PM
corvettebob1's Avatar
corvettebob1
Have you priced one to fit our cooling system lately?
Old Jun 28, 2010 | 02:11 PM
Z06Frank's Avatar
Z06Frank
Would you guy's drive the car like that ? the temps are not higher then normaly.
Old Jun 28, 2010 | 02:55 PM
wcsinx's Avatar
wcsinx
30k miles on an '02
Infrequent driving like that can usher in premature water pump death. They don't take kindly to sitting for long periods.
Personally I wouldn't have replaced the gaskets without also swapping in a new pump on a 8 year old car.
Old Jun 28, 2010 | 03:04 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by wcsinx
30k miles on an '02
My thoughts exactly! Ive never seen a pump gasket fail but,,,theres always a first time.
Old Jun 29, 2010 | 08:35 AM
elderberry's Avatar
elderberry
nope
I have one
the adapter was 30 bucks
the checker was 40 bucks years ago
but
most shops would check it for free
Old Jun 29, 2010 | 09:25 AM
Z06Frank's Avatar
Z06Frank
Alright so I guess my pump is going bad then...It will swap it out I guess it's not that expensive and not hard to replace.
Old Jun 29, 2010 | 09:44 AM
dougbfresh's Avatar
dougbfresh
Maybe a little more investigation is in order. A mirror and flashlight may help you see the proble.
The Batman's Avatar
The Batman
Sure, I did. Had a inconsistent leak on my 02 coupe, too, a few months ago. Sometimes no leak was evident, sometimes a 3" puddle. I used an old white plate to catch the leak when it first started, because it didn't look like orange Dexcool, but a more pink color. Turns out some formulations of Dexcool do turn pink.
I read on Corvetteforum that someone went through three gaskets on the driver's side before he fixed the leak. They're easy to install wrong, I guess.
Whenever something breaks, I see it as an opportunity to make it new again, so when I fixed my gaskets, I went ahead and bought a new pump (from NAPA). I looked over the old pump and didn't see any signs of a leak or failure, but I plan to keep my car forever, so I didn't mind buying a new pump.
Old Jun 29, 2010 | 03:42 PM
craig04c5's Avatar
craig04c5
My water pump went up at 31K miles. I have an 04 and I drive it almost every day.
Old Jun 29, 2010 | 05:10 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
replaced both gaskets on Wayne Gretz's 03 Z a couple of months ago after extensive research on here. seems the gaskets go bad from time to time on the LS1. pump itself looked great, reinstalled it with new gaskets and it is leak free...so far
To Leaking dexcool but where ??
