Seat Memory
Old Jun 28, 2010 | 12:38 PM
tgucc's Avatar
tgucc
Default Seat Memory
I have a 2001 coupe MN6 with the seat memory option. I can program the seat location. However when I set it up for easy access the seat moves back when I shut down the motor but when I get back in the car the seat doesn't go back to the #1 programmed position. Sometimes it doesn't move at all and sometimes it starts moving but doesn't make it back to the #1 stored position. If I press the #1 button it does go there.
Is it some sort of sensor?
Old Jun 28, 2010 | 01:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Try this:
Run your seat thru all if it ranges of travel a couple of times. Also do this to your mirrors. I had a simular issue on my Zo6 and this eliminated the issue. Cant say it s forsure fix but it sure wont hurt to try
Old Jun 28, 2010 | 01:41 PM
GreenDream's Avatar
GreenDream
Your car does not know if you are #1 or #2 unless you use the remote to unlock or press the appropriate memory button when you get in. It does not automatically go to a preset when you put the key in without the appropriate instruction.
Old Jun 28, 2010 | 03:14 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
On my 03 for the memory recall to function you must lock the car with the remote.
When you unlock with the remote and re-enter it will then recall the memory settings when you insert the ignition key.
Old Jun 29, 2010 | 11:04 AM
tgucc's Avatar
tgucc
Default Thanks
That's what it was. I have to depress the remote button for it to know who I am. It doesn't work when I'm getting in and out of the car when it's unlocked.
Old Jul 2, 2010 | 09:21 PM
GreenDream's Avatar
GreenDream
Originally Posted by 8VETTE7
Without using the remote or pressing the appropriate memory button the system doesn't know who you are. I also agree with Bill C.'s suggestion of running the seats and mirrors through their range of motions. I had read this in another post some time ago. I have a situation going on now where even when the system knows which driver is in the car, the seat and steering column acts strangely. When I put the key in the ignition they both come part way back to my preferred position. However I have to actually start the car for them to come fully back to the correct position. Seems to me it ought make the adjustment only once to my preferred position. It did some time back but is acting crazy of late. I have a Mn6 so I need to depress the clutch to be able to start the car. Currently the seat does NOT come forward far enough for me to fully depress the clutch to be able to start it without me sliding forward. I'm going to try Bill's suggestion to see if it helps.
Mine has been doing the exact same thing lately. Moving part way up and then finishing after I start it. Same problem here as mine is MN6 also. I do have long legs though. I have found that if you hit the memory button again it will go the rest of the way.
Old Jul 22, 2010 | 09:32 AM
prochargedbird's Avatar
prochargedbird
Default re
Hello everyone,
Just purchased a c5 zo6 and have no idea how to set the memory of the seats and mirrors, everytime I get back in I need to reset everything Grrrrrrr.
How do I reset the memory ?
Thanks Chris
Old Jul 22, 2010 | 11:04 AM
KrispyZ06's Avatar
KrispyZ06
Originally Posted by prochargedbird
Hello everyone,
Thanks Chris
After you get the seat/mirrors set how you want them, hold down the memory button on the door panel until the light blinks/turns solid.Very similar to setting a radio preset.
When all else fails read the manual that (should have) come with your car.
Old Jul 22, 2010 | 04:38 PM
prochargedbird
Thanks going out to try it now.
Wish I had a manual car didn't come with one.
Chris
Old Jul 22, 2010 | 04:42 PM
BigRobDsp's Avatar
BigRobDsp
My DS mirror points up and out every time I get in the car. no matter how many times I reset it. Any ideas on that?
Old Jul 22, 2010 | 04:53 PM
KrispyZ06's Avatar
KrispyZ06
Chris
http://www.corvetteactioncenter.com/...ual-links.html
Should be a link to the C5 oweners manual for free!
Old Jul 23, 2010 | 01:54 PM
dcandel's Avatar
dcandel
Oldtimer
I found the seat memory on my 99 a PITA so I programmed it off. I was always worried that it would fail and get stuck in the full back position.
Old Jul 23, 2010 | 05:30 PM
dklowrider's Avatar
dklowrider
Hello everyone,
Thanks Chris
all that, plus, don't forget to check the back of your key fob to see that you program the correct memory button. if the fob is #1 use #1 memory button, etc. if you mix it up it will drive you crazy and you'll think the car is possesed. don't ask me how i know.:o
To Seat Memory
